max_usb_current=1Worked perfectly thanks man. Should I get something like a powered USB hub or anything for future use?GTR2Fan wrote:Try adding the line......anywhere in your config.txt file.Code: Select all
max_usb_current=1
If you need talking through how to do this, just ask.
You're welcome. I wouldn't bother unless you have a specific need for one for something else. Just check that the Pi PSU isn't getting too warm running the HDD and you should be fine.jason118 wrote:Worked perfectly thanks man. Should I get something like a powered USB hub or anything for future use?
