jpie
Turn on TV
Fri Feb 26, 2016 8:19 pm
I'm setting up a program called TwoToneDetect which captures the A/B pager tones for the fire department and it can do different things once triggered.
One of the things I want to do is have it turn on a TV.
I'm honestly not sure where to start. I'm vaguely familiar with Pi/Linux (sudo, apt-get, basic commands) but otherwise I'm lost.
Anyone got some pointers or links to someone who may already have a script to turn a tv on some how? I'm not 100% sure that the TV we'll be using supports CEC, the TV obviously has IR and it also has the Samsung Ext "serial" port on the back.
Let me know if I can provide more info. Any help is appreciated.
jpie
Re: Turn on TV
Sat Feb 27, 2016 12:20 am
I've now learned of the "tvservice".
I started reading around and I tried the "tvservice -s" and it's only saying "DVI DMT", nothing about HDMI.
pi@raspberrypi:~ $ tvservice -s
state 0x120006 [DVI DMT (81) RGB full 16:9], 1366x768 @ 60.00Hz, progressive
I'm using a new HDMI cable, no adapters. Thoughts?
GTR2Fan
Re: Turn on TV
Sat Feb 27, 2016 12:42 am
I don't know whether this works for a TV or not, but typing vcgencmd display_power 1 in a terminal wakes my monitor up, and typing vcgencmd display_power 0 puts it to sleep.
The reason I've given those in reverse order is so that you can use the keyboard up-arrow followed by Enter to call the turn on command again blind or you'll be stuck with having to reboot the Pi to wake the display up. :D
Both work exactly as expected from inside a BASH script, so I'm fairly sure they will be accessible via other programming languages too.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
jpie
Re: Turn on TV
Sat Feb 27, 2016 12:50 am
Unfortunately it worked but didn't. It will sleep the screen but it won't "wake" it from a full off position. I've seen some TV's (Sharps) that can go into a light sleep (standby?) but I don't think this TV does that.
rzusman
Re: Turn on TV
Sat Feb 27, 2016 3:54 am
I use lirc to send IR commands to turn my Vizio TV on and off.
jpie
Re: Turn on TV
Sun Feb 28, 2016 1:44 am
What do you use for an IR blaster then?
rzusman
Re: Turn on TV
Sun Feb 28, 2016 2:09 am
I don’t - an IR led is easily bright enough to turn on the TV from where I have the Pi located.
It’s very easy to make a super-bright IR emitter. Just use a number of IR LEDs in parallel, driven by a MOSFET.
jpie
Re: Turn on TV
Sun Feb 28, 2016 4:22 pm
I'd really like to get this "tvservice" command to work if I can, nothing extra to add if it can work.
When I run any power on command it essentially blanks out the screen and the TV sees no input. Have to figure out what it's doing when it does that.
