Has anybody allready installed ruTorrent on raspberry pi?
Is there a tutorial available, or can anybody help me with the correct commands?
Thanks!
Re: ruTorrent
I got it setup with rtorrent and lighttpd. I mostly followed:
http://filesharefreak.com/2010/02/13/ho ... -or-debian
Re: ruTorrent
You can also use Transmission. It has it's own web interface on port 9091.
sudo apt-get install transmissiond
Re: ruTorrent
Now I have rtorrent and rutorrent running, but it's crashing after every half hour
Does transmission support rss feeds for automatic torrent downloading?
Re: ruTorrent
See this thread: http://www.raspberrypi.org/phpBB3/viewt ... &start=150twtb wrote:Now I have rtorrent and rutorrent running, but it's crashing after every half hour
After I updated my firmware and set the vm.min_free_kbytes to 16M I have been runing over 24 hours no issue. before i would run 2-5 mins and the pi would crash.
Re: ruTorrent
And where do you change min_free_kbytes?
I allready changed it in /etc/sysctl.conf, but it has no effect after reboot.
Re: ruTorrent
If you still having the issue then maybe it was the firmware update that fixed it for me. I used rpi-update to update my firmware to the latest.twtb wrote:And where do you change min_free_kbytes?
Re: ruTorrent
I have successfully used Transmission-cli on the latest Raspbian. No hitches, no adjustments, no crashes.
Any conversation about a sufficiently complex subject is indistinguishable from babble.
Re: ruTorrent
yet still, any success with this ?
Re: ruTorrent
You are replying to a four year old post.Skyway wrote:yet still, any success with this ?
If you are having a problem it is probably better to start a new post of your own, rather then looking at out-of-date information.
Re: ruTorrent
didn't watched the date, searched for rutorrent and here i ended.
Anyway i succeded in the end, but rtorrent does not work good with my pi. Too much wasted data..
