I am sorry that it took some while before I could continue with my How-To series around IBM Informix and sensor data on the Raspberry Pi, but from time to time I need to work on some real and exciting sensor data projects for my employer.
Just in case you might have missed my other posts on how to use IBM Informix for sensor data management on the Raspberry Pi, here are those articles:
viewtopic.php?f=37&t=97199&p=674959
viewtopic.php?f=37&t=97772&p=678497
viewtopic.php?f=37&t=100029&p=693935
Today I would like to show you how to configure and how to enable the REST API for Informix. The current developer edition of Informix for the RPi (12.10.UC6DE) includes a Java based REST and MongoDB compliant listener. Although Informix's MongoDB compatibility is a very interesting topic in itself, I am focusing today on the REST API listener alone.
The Informix REST API provides an open, very flexible and secure interface for developers who would like to utilize Informix's sensor (time series) data and relational capabilities without the need to dig too deep into Informix's other client development APIs. The API supports GET, POST, PUT and DELETE operations.
Through the REST API Informix can be also very easily integrated into JavaScript based frameworks like Node.js, Node-RED or any kind of client tools and libraries which support REST calls. As a side note: I am currently working on a simple Informix TimeSeries plugin for Grafana 2.6 (http://grafana.org/). That plugin also utilizes the Informix REST API.
Ok, so let's get started.
Since the Informix REST listener is java based, we need to make sure that we do have a Java JRE or JDK installed on the Raspberry Pi:
sudo apt-get install oracle-java8-jdkCode: Select all
cp $INFORMIXDIR/etc/jsonListener-example.properties $INFORMIXDIR/etc/restListener.propertiesCode: Select all
url=jdbc:informix-sqli://localhost:9088/sysmaster:INFORMIXSERVER=ol_informix1210;USER=<your_db_user>;PASSWORD=<your_db_user_password> # You shouldn't use user informix credentials here, if your REST listener is accessible from outside the Raspberry Pi due to potential security issues!
listener.hostName=*
database.share.close.enable=true
listener.idle.timeout=3000
listener.port=<your desired port number for the REST API eg. 8080>
listener.http.accessControlAllowOrigin="*"
listener.type=rest
pool.size.maximum=2
pool.connections.maximum=4
pool.type=advanced
response.documents.count.default=10000 # or any desired number
pool.idle.timeout=60
security.sql.passthrough=true # only set this property to true if you would like to use the SQL pass through feature!
java -cp $INFORMIXDIR/bin/jsonListener.jar com.ibm.nosql.server.ListenerCLI -config $INFORMIXDIR/etc/restListener.properties -logfile $INFORMIXDIR/tmp/restListener.log -loglevel error -startCode: Select all
nohup java -cp $INFORMIXDIR/bin/jsonListener.jar com.ibm.nosql.server.ListenerCLI -config $INFORMIXDIR/etc/restListener.properties -logfile $INFORMIXDIR/tmp/restListener.log -loglevel error -start &> /dev/null & With the following example URL I am fetching all time series data from the VTI table 'sensor_data':
http://localhost:8080/sensor_db/sensor_dataCode: Select all
http://localhost:8080/sensor_db/sensor_data?query={"sensor_id":"Sensor01"}Code: Select all
http://localhost:8080/sensor_db/sensor_data?query={"sensor_id":"Sensor01"}&fields={"timestamp":1,"value":1}Ok now let's provide a slightly more complex query through the REST API by providing a time stamp range:
http://localhost:8080/sensor_db/sensor_data?query={"$and": [{"sensor_id":"Sensor01"},{"timestamp":{"$gte": {"$date":1289347200000}}},{"timestamp":{"$lt": {"$date":1297122300000}}} ]}&fields={"timestamp":1,"value":1}Code: Select all
http://localhost:8080/sensor_db/sensor_data?query={"$and": [{"sensor_id":"Sensor01"},{"timestamp":{"$gte": {"$date":"2016-02-24T15:00:00.000Z"}}},{"timestamp":{"$lt": {"$date":"2016-02-24T15:30:00.000Z"}}} ]}&fields={"timestamp":1,"value":1}If you have set the listener property 'security.sql.passthrough=true' (again, be careful in doing so!), you can send any SQL command to the Informix database. In the following example I am sending a SELECT statement through the REST API to Informix which returns the last entry of a time series:
http://localhost:8080/sensor_dbsystem.sql?query={"$sql":"select GetLastElem(sensor_values).value from sensor_ts where sensor_id = 'Sensor01'"}I think by now you should hopefully have enough information to get you started with the Informix REST API.
Since Informix's REST API is much more powerful than I could have described in such a short introductionary article, I would recommend that you take a look at the following online documentation:
- REST API Syntax: https://www-01.ibm.com/support/knowledg ... on_051.htm
- REST API and time series data queries: https://www-01.ibm.com/support/knowledg ... on_065.htm
- General information about the Informix listener: https://www-01.ibm.com/support/knowledg ... on_004.htm
- http://www.slideshare.net/IBM_Info_Mana ... h-informix
- http://www.slideshare.net/IBM_Info_Mana ... s-solution
Since I briefly mentioned Node-RED in the intro of this post, let me also point you to a set of Informix Node-RED time series nodes which utilize the Informix REST API:
http://flows.nodered.org/node/node-red- ... timeseries
I am using those nodes quite often on my Raspberry Pi to pre-aggregate sensor data before they are sent into the cloud.
And finally: have fun using the Informix REST API in combination with the Informix time series capabilities!
- Alexander
