CHARL13IS
Official RPi WiFI on Native Wheezy
Wed Feb 24, 2016 3:30 pm
Hi Guys
I've taken delivery of an official RPi wifi dongle and I'm trying to get it working with a native Wheezy install. When I try and assign a static IP address to it I get the error: "wlan0: ERROR while getting interface flags: No such device".
I'm guessing I'm missing some drivers, but I can't seem to find them, or instructions on how to install them. Has anyone come across this before?
Re: Official RPi WiFI on Native Wheezy
Wed Feb 24, 2016 4:52 pm
CHARL13IS wrote:Hi Guys
Wheezy last release was July 2015 and supports the BCM43143 WiFi Chooser natively..
Retired disgracefully.....
......to a more gentile life !
CHARL13IS
Wed Feb 24, 2016 5:00 pm
Thanks for your response. I'm running a minimal install of Wheezy, which I found here. Is it possible that the module isn't part of the minimal image? Apologies I'm quite new to Linux.
Wed Feb 24, 2016 5:04 pm
CHARL13IS wrote:Thanks for your response. I'm running a minimal install of Wheezy, which I found here. Is it possible that the module isn't part of the minimal image? Apologies I'm quite new to Linux.
Any reason not to use the current Raspbian Jessie Lite ? https://www.raspberrypi.org/downloads/raspbian
CHARL13IS
Wed Feb 24, 2016 9:23 pm
fruitoftheloom wrote:Any reason not to use the current Raspbian Jessie Lite ? https://www.raspberrypi.org/downloads/raspbian
My preference is native Debian. I've tried the Raspbian Jessie Lite distro to prove the dongle is good, which it is. I noticed that the firmware-brcm80211 version on the Raspbian distro is 0.43+rpi3, where as on native it's just 0.43.
I've copied the sources.list entries from the Raspbian distro to native but it made no difference.
CHARL13IS
Thu Feb 25, 2016 6:11 pm
I've fixed it. Although I have switched to native Jessie, this might well work on Wheezy as well. For anyone else in the same boat I did the following:
Edit the sources
nano /etc/apt/sources.list
Add the following line and save
deb http://archive.raspberrypi.org/debian jessie main
Run the following
apt-get update
If you get an error about public keys, run the following
gpg --keyserver pgpkeys.mit.edu --recv-key 82B129927FA3303E
gpg -a --export 82B129927FA3303E | apt-key add -
And finally
apt-get install firmware-brcm80211
ifconfig wlan0 up
Return to “Debian”
