Xynus
Re: How to setup Minecraft 1.8.9 on RaspPi2
Thu Oct 26, 2017 10:45 am
AH, alright. Would the guide be located in this thread, or is it in a different one?
rpiMike
Thu Oct 26, 2017 10:49 am
In the link in my first reply to you.
Xynus
Fri Oct 27, 2017 1:44 am
Hey. I tried the aforementioned method, but it didn’t work. I got no error message, only a white minecraft window with nothing running. Could you give it a try and tell me your results?
trnt
Sat Oct 28, 2017 6:21 am
What Minecraft version is this? I've got the same problem by starting Minecraft 1.0 and 1.1 with the launcher(Yes, that's possible, newer versions are not possible to be started in the launcher
Xynus
Sat Oct 28, 2017 12:52 pm
I’m attempting Beta 1.1_02
Frederk
Sun Nov 26, 2017 8:17 pm
I tried this but it keeps saying 'unsatisfied link error' even though I did step 7 and 8 multiple times.
rpiMike
Sun Nov 26, 2017 8:34 pm
Are you after this specific version 1.8.9 ? Have you seen the new 1.12.1 tutorial ?
When do you get the error ? Are you on Raspbian Stretch ? Did glxgears work at 60fps ?
Frederk
Sun Nov 26, 2017 9:34 pm
I did the 1.12 tutorial and now it worked! Don't know what was wrong...
trnt
Fri Dec 01, 2017 1:28 pm
That could be caused from spelling mistakes. I had the same probloem until I discovered the mistake
trnt
Sat Dec 02, 2017 7:43 am
I get the Unsatisfied Link Error when I try to play mineraft using the launcher.
Play Minecraft by entering:
cd Minecraft
./run.sh
ToxicFragz5665
Fri Dec 08, 2017 2:21 am
how can i join servers...
whenever i try i get access token can be null :roll:
rpiMike
Fri Dec 08, 2017 1:38 pm
There is a link to a run script somewhere in this thread that will connect to servers. Alternatively the 1.12.1 tutorial connects to servers.
ToxicFragz5665
Sat Dec 09, 2017 12:35 am
can u send me the link,
i was able to go on servers on 1.12 but i tried a little diff on 1.8.9 and didnt work :shock:
Xynus
Sun Dec 10, 2017 4:59 pm
Hello again!
I'm attempting to reinstall the game, but whenever I attempt to install Optifine, it calls an error;
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:225)
at java.util.zip.ZipFile.<init>(ZipFile.java:155)
at java.util.zip.ZipFile.<init>(ZipFile.java:169)
at optifine.Patcher.process(Patcher.java:71)
at optifine.Installer.installOptiFineLibrary(Installer.java:308)
at optifine.Installer.doInstall(Installer.java:94)
at optifine.InstallerFrame.onInstall(InstallerFrame.java:425)
at optifine.InstallerFrame.connEtoC1(InstallerFrame.java:490)
at optifine.InstallerFrame.access$7(InstallerFrame.java:484)
at optifine.InstallerFrame$IvjEventHandler.actionPerformed(InstallerFrame.java:46)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6533)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6298)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Does anyone know a fix for this?
catsettos
Optifine
Mon Mar 05, 2018 4:37 pm
I followed the steps in @Sindybad's tutorial on the first page and I keep getting the message
"Error: Could not find or load main class net.minecraft.launchwrapper.Launch"
and nothing happens. If anyone knows how to fix this please do :D
rpiMike
Mon Mar 05, 2018 5:48 pm
Are you after 1.8.9 specifically ? My instructions for 1.12.1 include Optifine (link at top of first page).
Zenmama11
Sat May 05, 2018 3:38 am
Please help
I have poured over this thread over and over and I am stuck on this:
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Error: Could not find or load main class net.minecraft.client.main.Main
I have followed the steps to the best of my knowledge but clearly I am doing something wrong...
I am running pi3
I have version Oracle 8 for java
I have tried using version 1.8.9 in the minecraft launcher under edit profile
my glx gears are running around 38 fps but I saw someone else said they got it to work around this rate
I have updated my login info in the .sh file and put " " around my password because of a special character
....and I am almost ready to give up
So I digress, Please help
rpiMike
Sat May 05, 2018 1:48 pm
Are you running the latest Raspbian Stretch ? glxgears should be close to 60fps, are you using an hdmi screen and decent psu?
Did you edit anything other than username and password in the run.sh. The script in the tutorial is specific to version 1.8.9.
Any reason your not using the 1.12 tutorial?
LoLec
Mon Oct 08, 2018 12:37 pm
Hello! Could you do a 1.6.4 version with forge (for mods) please? I would like to run Minecraft 1.6.4 with Sim U Kraft mod.
LoLec
Mon Oct 08, 2018 6:37 pm
What about forge? (For mods). Would be nice to play minecraft with mods on the raspberry pi 3. P.S i have a RPi 3 Model B+.
LoLec
Fri Oct 26, 2018 8:20 am
Can i run 1.6.4 on the raspberry pi 3? And is it possible to play with Forge and mods?
avensis
Fri Oct 26, 2018 6:37 pm
Hello, I wanted to know how to run 1.6.4 on the Raspberry Pi 3 if it's possible, thanks.
____________________________________________________
https://downloader.vip/the-pirate-bay/
https://downloader.vip/yify-yts/
https://www.oovoo.com/rargb/
Return to “Gaming”
