Thanks for your replyFTrevorGowen wrote:Which particular dongle? Can you post the output of lsusb and usb-devices? What else (if anything) have you plugged in to the USB ports and have you enabled the higher USB current setting (ie. max_usb_current=1 in config.txt) Did you (need to) do that with the B+? What version of (which) O.S. are you using? (Eg. the output of uname -a perhaps)
Trev.
For the benefit of those that know more about specific WiFi dongles (than me) the extra info. w.r.t. model type, chipset, driver (trying to be used) and current (MxPwr) requirements may provide a clue or two. For example, I'm aware from other threads that at least one dongle of the "same" model type has changed chipsets/driver at least once.ManicalEngineer wrote:Okay so I can't post the complete output of those commands because the pictures are too big for the forum and I can't get the pi connected to the Internet. But I checked my answers from earlier and they are correct is there additional information you were looking for?
You could upload the pictures elsewhere and post a link to them here. I usually copy photos to Google Drive then provide a public link from there.ManicalEngineer wrote:Okay so I can't post the complete output of those commands because the pictures are too big for the forum...
Bus 001 Device 006: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev=04.01
S: Manufacturer=Linux 4.1.15-v7+ dwc_otg_hcd
S: Product=DWC OTG Controller
S: SerialNumber=3f980000.usb
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 5
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=02 MxPS=64 #Cfgs= 1
P: Vendor=0424 ProdID=9514 Rev=02.00
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=2mA
I: If#= 0 Alt= 1 #EPs= 1 Cls=09(hub ) Sub=00 Prot=02 Driver=hub
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0424 ProdID=ec00 Rev=02.00
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=smsc95xx
T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#= 4 Spd=1.5 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=046d ProdID=c31c Rev=64.00
S: Manufacturer=Logitech
S: Product=USB Keyboard
C: #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=90mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=01 Driver=usbhid
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=03 Dev#= 5 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0bda ProdID=8176 Rev=02.00
S: Manufacturer=Realtek
S: Product=802.11n WLAN Adapter
S: SerialNumber=00e04c000001
C: #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=ff Prot=ff Driver=rtl8192cu
T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=04 Dev#= 6 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=046d ProdID=c52b Rev=12.01
S: Product=USB Receiver
C: #Ifs= 3 Cfg#= 1 Atr=a0 MxPwr=98mA
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
I: If#= 2 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
Possibly not. Jessie changed the way networking worked and was configured over how it was done with Wheezy. I had a similar problem when I upgraded. I believe, but don't quote me, that it's down to one particular package, the name if which escapes me right now. (I'm in bed!)I found other posts which indicate that when they changed OS's from Wheezy to Jessie that they had connection issues, which leads me to believe its a flaw in the raspbian-jessie OS.
Does it connect to open networks? If it doesn't, this is likely a different problem to someone who can connect to open networks but not ones that are secure in various ways.ManicalEngineer wrote:The wifi adapter appears to be working fine, shows up when I run lsusb, detects networks but when ever I attempt to connect to my network it just doesn't work regardless of w
I don't currently have access to an open network at the moment. Tomorrow after work I can open it up.stderr wrote:Does it connect to open networks? If it doesn't, this is likely a different problem to someone who can connect to open networks but not ones that are secure in various ways.ManicalEngineer wrote:The wifi adapter appears to be working fine, shows up when I run lsusb, detects networks but when ever I attempt to connect to my network it just doesn't work regardless of w
You'll need to divide solving this into a process that you take step by step, unless it just suddenly fixes itself, which always makes me sad because I'm really keen on finding and following through on a process. Doing that tends to be more repeatable.
Norm,NormanDunbar wrote:Evening,
Hmm, strange that it doesn't work for you. Did you put /etc/network/interfaces back to a default set of settings? I assume so.
Do you see anything in /var/log/messages or when using dmesg|tail -50 when you plug in the dongle and when you try to connect?
Do you have a non pi computer to test the dongle in?
Do you have wpa supplicant installed? Configured? An open wireless access point is not a good thing these days.
Cheers,
Norm.
You may be right, that's consistent with my dongles working O.K. with a WPA based router. I've never tried them with my oldest, WEP-based router, which is "piggy-backed" onto the main one to give improved "coverage upstairs".dgordon42 wrote:I think WEP security is the problem. WEP security is easy to crack, and was replaced by WPA security many years ago.
See this post on how to configure the wpa_supplicant.conf file to work with WEP security.
Hope this helps,
Dave.
Often you can find an open network that will at least let you connect. It used to be that home users left them open but then everything but some coffee seller offering Free Wifi for their customers was locked down with something. If it's locked with anything including WEP, you shouldn't attempt connecting because someone might call that "hacking".ManicalEngineer wrote:I don't currently have access to an open network at the moment. Tomorrow after work I can open it up.
Of course you shouldn't leave your system open, those hackers will probably hack you. Or someone trying to figure out why their pi won't connect might connect for a few seconds.So for sake of argument lets say that works, I can't leave the network open what is the next step in this journey?
sudo ifup wlan0Code: Select all
interface = {Code: Select all
interface={Code: Select all
sudo ifup wlan0If you have the wifi part figured out, now you should figure out the local network itself. Why are you getting an odd ip address on the pi? Is it dhcp to the router? If it is, are other devices getting their ip within the same odd network? If they are not and you are doing your pi ip static, then perhaps you typed in the ip wrong. The first question now is what subnet do the other devices including the router, everything that works now, what do they think it is? If it's 192.168.0.0/24 and the pi thinks that it is 198.168.0.0/24, then obviously a change is in order. Type:ManicalEngineer wrote:Norm,
Funny enough, I haven't gotten online, but I have managed to get connected to the router. I run ifconfig, and get an IP address but it doesn't seam right (198.168.0.10). When I check from the router side, I can see the Pi's MAC, but no IP is listed. I have no idea where to go from here.
$ lsusb
Bus 001 Device 003: ID 0a5c:bd1e Broadcom Corp.
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
iface wlan0 inet manualCode: Select all
iface wlan0 inet dhcpCode: Select all
sudo cat /etc/resolve.confWhen you are at that point, you have a connection outside your network, you usually just need the /etc/resolv.conf working. Make sure there is a sane name server in there:ManicalEngineer wrote:However still not all the way there! I can SSH in to the pi on my local network, the IP makes sense, I can ping 8.8.8.8 and the router IP successfully BUT I can't to anything through a typical web address via the browser. Also apt-get fails when trying to access web addresses.
