amandeepsingh
Disable trash icon from desktop using command line
Mon Feb 22, 2016 1:28 pm
Hey Guys,
I want to remove the Trash icon (Wastebasket) from the desktop using command line. Is there any way to do this? I didn't find anywhere. I'm able to done this using GUI but not from command line.
Any help much appreciated :D
mleffler
Re: Disable trash icon from desktop using command line
Fri Oct 04, 2019 1:37 pm
I found this post when looking for an answer to this question, so I figured it was a good enough place to post the answer I figured out.
In my case I wanted to change this for all user accounts to be created, so I changed the config at:
/etc/xdg/pcmanfm/LXDE-pi/desktop-items-0.conf
With the edit:
show_trash=0
If you're wanting to do this for a particular user the config would be located at (pi is the user in this example):
/home/pi/.config/pcmanfm/LXDE-pi/desktop-items-0.conf
FYI found this by using a file watcher script mentioned here:
https://www.raspberrypi.org/forums/view ... 7#p1424687
Return to “Teaching and learning resources”
