I ordered my first RPi from RS Components in late June. I haven't heard anything since. I ordered numbers 2 and 3 on July 3, and have received them both already. I figure the one from RS will come eventually.
I had a difficult challenge getting either RPi to run properly. I tried many different things until I finally measured the voltage across tp1/tp2. I found it alarmingly low (somewhere in the 3.8v range). So I have been testing various power sources that I have in my electronics graveyard. I am surprised that very few of them are adequate. I tested with a 4GB SD card plugged in, and nothing else. The best my genuine ipad charger could do is 4.4v. The motorola lapdock could muster only 4.5v with HDMI plugged in. The best was a little Lenmar battery (ipod charger) that got up to 4.8v. The lesson I learned (which most people here have already discovered), is that the average charger will not do. I will look for something better.
But here is the intriguing thing: I tested both of my RPis. One of them consistently shows about 0.4v lower than the other, regardless of which power supply I use. Everything else is the same between them. Could this other RPi with the lower voltage be defective? Could it still be okay as long as I supply enough power to it?
I welcome your thoughts.
Thanks,
Dave
