davenull
openVG compile/build parameters
Thu Feb 18, 2016 3:49 pm
hey
as I read, for compile / build the parameter option
-I/opt/vc/include/interface/vcos/pthreads
should be required, but I am already using
-pthread
as a parameter.
Is the 1st one needed anyway? what is this for then?
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
Paeryn
Re: openVG compile/build parameters
Thu Feb 18, 2016 8:31 pm
davenull wrote:hey
-pthread
as a parameter.
-I/opt/vc/include/interface/vcos/pthreads tells the compiler where to find some of the header files that are used by the CPU-side drivers to (presumably) interface with the pthreads implementation on the VC4.
-pthread just tells the compiler to include the pthread library for the CPU (and add any needed #define's).
Both are needed.
davenull
Fri Feb 19, 2016 8:12 am
aha, thank you, again become a bit wiser 8-)
Return to “OpenVG”
