Speedy2k wrote:But what can cause that??
There is a very long list of possible causes and I would only be speculating as I have no information to go off...
Check your logs, find the error(s) look for a pattern.
My guess is you have a lot of IO. If something is causing a lot of IO it will wear out the SD cards pretty quickly.
Thats just a guess though, you need to examine and monitor till you get to the bottom of it. One thing is for sure, there will be a reason as you have 4 already.
