aberts10 wrote:ok so I disabled overscan, changed the resolution to 720x480... but its going off the screen...
I fixed the sharpness problem sortof... I'm going to turn on overscan and try and change the scale.
EDIT: I think its just the TV... no matter what I do I still am getting a distortion to the color and sharpness and if you look closely you can see the screen updating... distortion of the slightest white that caries up the screen and disappears...
One problem I have had is that the graphics in many old programs seem to be hardcoded to a specific minimum VGA screen size which is larger than the composite screen. Menus go off the screen so it's impossible to see or navigate to all the menu choices or the playing field of a game goes off the screen which makes it impossible to play. Like you, I am in US so stuck with NTSC. PAL may be better in that regard.
I have heard that the frame buffer on RPi can be adjusted to help but haven't tried that.
Composite video was made for motion video and was never intended to show that much static images or text like is generated by a computer.
Text is typically jittery, blurry and hard to read. I find composite from RPi on an old CRT TV is almost unusable..... gives me a headache. Composite is a bit better when shown on a LCD screen.
