Hello
I am trying to run a keyboard on RaspberryPi zero via OTG cable (bought Raspberry Pi zero + essentials kit)
I have fresh jessie image on my SD card and I connect to my pi via enc28j60
Can I ask for some help?
pi@raspberrypi0:~ $ tail -f /var/log/syslog
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Timers.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Timers.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Sockets.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Sockets.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Basic System.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Basic System.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Starting Default.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Reached target Default.
Feb 18 19:18:16 raspberrypi0 systemd[650]: Startup finished in 61ms.
Feb 18 19:18:16 raspberrypi0 systemd[1]: Started User Manager for UID 1000.
Feb 18 19:18:47 raspberrypi0 kernel: [ 206.959939] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:47 raspberrypi0 kernel: [ 207.139851] usb 1-1: new low-speed USB d evice number 6 using dwc_otg
Feb 18 19:18:47 raspberrypi0 kernel: [ 207.141407] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:47 raspberrypi0 kernel: [ 207.319793] usb 1-1: device descriptor r ead/64, error -71
Feb 18 19:18:47 raspberrypi0 kernel: [ 207.431269] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:47 raspberrypi0 kernel: [ 207.609794] usb 1-1: device descriptor r ead/64, error -71
Feb 18 19:18:48 raspberrypi0 kernel: [ 207.719909] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:48 raspberrypi0 kernel: [ 207.899798] usb 1-1: new low-speed USB d evice number 7 using dwc_otg
Feb 18 19:18:48 raspberrypi0 kernel: [ 207.901293] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:48 raspberrypi0 kernel: [ 208.079786] usb 1-1: device descriptor r ead/64, error -71
Feb 18 19:18:48 raspberrypi0 kernel: [ 208.191470] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:48 raspberrypi0 kernel: [ 208.369797] usb 1-1: device descriptor r ead/64, error -71
Feb 18 19:18:48 raspberrypi0 kernel: [ 208.479914] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:49 raspberrypi0 kernel: [ 208.659808] usb 1-1: new low-speed USB d evice number 8 using dwc_otg
Feb 18 19:18:49 raspberrypi0 kernel: [ 209.079789] usb 1-1: device not acceptin g address 8, error -71
Feb 18 19:18:49 raspberrypi0 kernel: [ 209.079932] Indeed it is in host mode hp rt0 = 00041901
Feb 18 19:18:49 raspberrypi0 kernel: [ 209.259798] usb 1-1: new low-speed USB d evice number 9 using dwc_otg
Feb 18 19:18:50 raspberrypi0 kernel: [ 209.679804] usb 1-1: device not acceptin g address 9, error -71
Feb 18 19:18:50 raspberrypi0 kernel: [ 209.679928] usb usb1-port1: unable to en umerate USB device
