I've successfully set up RPi Cam Control (running v6.0.28) and have been experimenting with settings here and there.
I'm wondering how I can max out the capabilities of the pi->cam->streaming setup.
After some research, it seems the CPU of the Pi is the main bottleneck.
I'm more than happy to purchase a higher resolution camera, network gear that can handle the bandwidth throughput (Currently using a Nighthawk R7000), and whatever else hardware might need to be upgraded.
Just curious what driver+hardware+settings combo you guys have found to produce the best resolution and at what framerate.
My current settings in the RPi Cam Control interface that I'd like to improve:
Video res: 768x576 (this seems to be the live res)
Preview Quality 8
Everything else more or less default
I know this camera is capable of much higher res than this:
