Lxw2015
jessie password
Sun Feb 14, 2016 4:40 am
I just installed jessie OS. when I open terminal, it shows [email protected] I assume that pi is user name, and it did not ask me for password.
now I use putty try to login to my pi, my raspberrypi IP is 192.158.0.45 so type Host Name as [email protected]
but it ask me for password. what is the password for this?
thanks
Lxw
upojzsb
Re: jessie password
Sun Feb 14, 2016 4:45 am
Default User is pi
Default password is raspberry
English is not my mother tongue, so I might do some grammatical error , please understand , thank you.
Lxw2015
Re: jessie password
Sun Feb 14, 2016 6:28 am
I tried both , neither work.
DirkS
Re: jessie password
Sun Feb 14, 2016 3:37 pm
Lxw2015 wrote:I tried both , neither work.
What do you mean by both?
The default password is 'raspberry', all lower case. You will not see any output when entering the password.
Are you using a qwerty keyboard?
Lxw2015
Re: jessie password
Sun Feb 14, 2016 5:31 pm
thank you. PW is raspberry.
I tried "pi" and "raspberrypi".
now I connected to my pi using putty ;)
stderr
Re: jessie password
Sun Feb 14, 2016 5:37 pm
Lxw2015 wrote:thank you. PW is raspberry.
To be clear for anyone reading this six months later, and if I'm wrong I'm sure I'll be corrected, but it's:
ssh [email protected]
You will then be prompted for a password which is:
raspberry
If you have problems, try ssh -vvv [email protected] to see all the back and forth messages as ssh tries to connect. Fewer -v mean messages are more focused on what is likely to be important.
asandford
Re: jessie password
Sun Feb 14, 2016 6:30 pm
stderr wrote: To be clear for anyone reading this six months later, and if I'm wrong I'm sure I'll be corrected, but it's:
raspberry
That will work only on *nix systems with avahi installed, won't work on windows unless you install the Apple Bonjour service. (And you were right about someone not really correcting you, but giving additional information :) )
do_marie
Re: jessie password
Tue Sep 27, 2016 8:31 pm
maybe you have an english or french or other keyboard.
choose th good ketboard
Menu>preferences>mouse & keyboard > keyboard> keyboard layoout > your country
it worked for me (i've not englisk keyboard, i wrote rqsberry !)
bulletprasath
Re: jessie password
Tue Dec 20, 2016 11:57 am
i bought the raspberry as used one. on a new sd card installed rasbian and connected to my laptop with ethernet cable. connected to pi with putty.
then it asked for "login as:" (entered) pi
[email protected] 169.254.xxx.xxx's password: (entered) raspberry
Access denied
tried raspberrypi as well, but its not working.
is the username password bound to OS or the device memory (like EEPROM)?
(i feel its bound to OS), but reformating (low level format, then FAT32) and re-writing rasbian didn't work either
help me I'm going nuts over this.
PS: access to a hdmi monitor is kinda difficult, so gotta use only putty
kamik95
Re: jessie password
Sat Dec 24, 2016 9:29 pm
Hi, in the lastest raspbian image, the SSH is disabled by default:
https://www.raspberrypi.org/blog/a-secu ... ian-pixel/
bulletprasath wrote:i bought the raspberry as used one. on a new sd card installed rasbian and connected to my laptop with ethernet cable. connected to pi with putty.
Access denied
Martin Frezman
Re: jessie password
Sat Dec 24, 2016 9:37 pm
kamik95 wrote:Hi, in the lastest raspbian image, the SSH is disabled by default:
How can that possibly be relevant to anything?
OP says he was prompted for password - if SSH server were not running, you would not get prompted for password.
Edit: OP says he is using Putty - but doesn't state which OS he is using it on (from). It may well be that under certain circumstances, using certain versions of Putty on certain OSes, it would prompt you even if the target machine isn't running the SSH server.
My experience is to the contrary - usually if the server isn't running, I never get to a password prompt.
If this post appears in the wrong forums category, my apologies.
