A rare thing:
I always workd with a Retropie install from the last summer and updating that eventually (system update and upgrade, download the last RetroPie Script compilation...) everything runs awesome, better sometimes, others not, but some change can always fix that.
But i was busy the last months and i keep the same stuff that time on my custom retropie pack.
The problem is the last weekend i upgraded everything and all is ok, really nice new video driver, but the PS3 pads with the bluetooth now don't work.
With some hope i tried to download and install the new RetroPie Image (1.3) but i get the same result:
sixad says "unable to connect to sdp session" and the pads leds don't stops to blink. I'm sure that the pads are correctly paired with the bluetooth (sixpair).
I give up, i will return to my old Retropie image. I'm the only one with that problem now?
Another thing:
I see that by default the es_systems files have new emus on GameGear,MasterSystem,Megadrive and NeoGeo. None of them work, but with my old config lines now works fine, if that helps somebody...:
GameGear & Master System:
COMMAND=retroarch -L /home/pi/RetroPie/emulatorcores/Genesis-Plus-GX/libretro.so %ROM% --config /home/pi/RetroPie/configs/all/retroarch.cfg
MegaDrive:
Nothing, sure that DGEN runs better than Genesis-Plus, but on analog output only offers a black screen.
NeoGeo:
COMMAND=retroarch -L /home/pi/RetroPie/emulatorcores/imame4all-libretro/libretro.so %ROM% --config /home/pi/RetroPie/configs/all/retroarch.cfg
(Runs perfect with the mame4all romset but don't save high scores)
Spectrum:
Don't work from ES ¿?¿?
eDuke32:
Never worked
PSX:
Very very very nice to use isos in .CBN format, that fixes the boot error of some games, the compression are higger, don't rips the soundtracks, more compatibility and faster reading system by blocks.
But that are small issues, i like too much the idea of a standard image and I only have to say congratulations for the project, that is growing fast! Can i help in some way? Maybe is usefull to share my config of the systems, pads, some script to select the kind of input to use before start ES, add mp3 music during the gameplay, themes, etc...
Sorry, my english is awful, like me. XD
