In addition, I've also seen references to hardware designed for servo function, such as: https://www.adafruit.com/products/815
I would like to tinker around and use some sensors and write a program to automate control of the servos using the PI based on sensor inputs.
I would appreciate any lessons learned about using multiple servos with the PI. FYI: I would be willing to spend some money to get an optimal setup if that meant higher precision/less servo jitter, or simply easier to work with.
