studysession
Playing a DVD Should be simple
Wed Feb 10, 2016 3:30 am
Playing a DVD Should be simple but it is not....
I have my license for MPG2 loaded. I have the basic Raspbian 1.6 load. I search this site and google and nothing is straight on getting it to play a DVD on my RasPi.
It see the drive
It sees the disk
MPG2 is enabled
Now what do I do to play the DVD?
No I am not loading the dedicated multimedia play setup. I should be able to do this on the standard Raspbian load.
elatllat
Re: Playing a DVD Should be simple
Wed Feb 10, 2016 8:10 am
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
studysession
Wed Feb 10, 2016 5:39 pm
Thank you - I installed gxine and it recognizes that DVD. But it exits saying:
libsvsread: Encrypted DVD support unavailable
I thought the MPEG-2 codec was to allow me play encrypted DVD's.
All the searching on this forum and across anything Google - most of the posts and replies not shown me a real anything I can get working. The command for codec status shows it is enabled.
Totally lost on how to watch these on the Raspbian load.
Wed Feb 10, 2016 5:47 pm
MPEG-2 License Key
This key will enable a single Raspberry Pi to decode MPEG-2 video in hardware.
It is not for unencrypting, you need as stated in the link libdvdcss2
viewtopic.php?f=35&t=134012
https://wiki.debian.org/CDDVD
RPi 4B 4GB (SSD Boot)..
Wed Feb 10, 2016 5:50 pm
The MPEG-s codec lets you play MPEG-2 videos. DVDs contain encrypted MPEG-2 videos. The codec doesn't do decryption.
You can install some software called libdvdcss2 which decrypts the DVD, but I don't believe it is available from the standard Raspbian sources because it may be illegal to use in some countries.
dgordon42
Wed Feb 10, 2016 6:52 pm
You might get lucky with the brasero package. For more information:
apt-cache show brasero
I have not used it, so I don't know what it can do.
Dave.
Wed Feb 10, 2016 6:57 pm
dgordon42 wrote:You might get lucky with the brasero package. For more information:
Dave.
Brasero is an application to burn CD/DVD for the Gnome Desktop. It is designed to be as simple as possible and has some unique features to enable users to create their discs easily and quickly.
https://wiki.gnome.org/Apps/Brasero
studysession
Wed Feb 10, 2016 7:06 pm
I did get libdvdcss downloaded and installed.
Unsure if it was needed but I did a reboot just in case.
Everything seems to recognize it is a movie DVD but still cannot play it.
Wish there was something I could easily figure out.
jbeale
Wed Feb 10, 2016 7:29 pm
I haven't tried to do this on the RPi, so I can't offer useful advice. Not that it helps you, but... I understand as a consumer you would expect playing a DVD to be simple. The organizations that own the DVD format standards intentionally made it difficult. MPEG2 license != DVD player license. They wanted to prevent un-approved DVD players from playing CSS-encrypted DVDs (that is nearly all commercial DVD titles), for reasons such as enabling studios to release films in different parts of the world at different times, not permitting the user to skip previews and anti-piracy warnings, and so forth.
studysession
Wed Feb 10, 2016 7:40 pm
So cool -
Now just have to get the video to keep up but I am a step closer.... After installing libdvdcss I have to do the following to make the programs recognize it
sudo cp /usr/local/lib/libdvdcss* /lib
studysession
Wed Feb 10, 2016 8:07 pm
got everything working thanks for all the help..... still need to figure out screen refresh and stuff but it works
studysession
Wed Feb 10, 2016 11:16 pm
Hopefully me writing this blog post will be helpful to others
http://www.doingitwithraspberrypi.com/2 ... -pi-2.html
jbeale
Wed Feb 10, 2016 11:19 pm
That looks very clear and straightforward; thanks for writing that up!
ghans
Thu Feb 11, 2016 6:34 am
You should propably use mplayer to dump the DVD
and have omxplayer read the dumped data (using named
pipes).
That is because only omxplayer uses both the license
code and hardware acceleration. If you are happy with
mplayers performance now , that pretty much means you
actually didn't need to buy the license in the first place
( i.e. software decoding is fast enough for you) ...
ghans
emma24xia
Thu Feb 09, 2017 8:43 am
I encounter the same problems as you.
mikerr
Thu Feb 09, 2017 8:55 am
I remember getting this working a couple of years ago:
http://raspi.tv/2012/watch-encrypted-dv ... -omxplayer
