Wed Feb 10, 2016 1:01 am
I guess I am on the right track. I have my RPI setup as master and my arduino uno setup as slave and they communicate via i2c. it's working fine in my current code. The arduino has a photocell hook up on a analog pin and it send back light read to the PI and the PI make the led on a 10 led bar go on and off depending of the light source. My problem it's when I try to modify my code to send data requesting for other info... I thought I understood how the 2 communicate, I guess not. Here the code I'm using, have a look and tell me if you have a idea how to do this.
Here a scenario:
1- when the PI come up, send to arduino are you alive, arduino kind of send back an acknowledgement
2 - PI request light output, arduino send the light output
3 - PI request Temp sensor data, arduino send all or only the specific you ask
arduino code
#include <Wire.h>
#include <FastIO.h>
#include <I2CIO.h>
#define SLAVE_ADDRESS 0x04
int number = 0;
int state = 0;
int photocellPin = 0;
int photocellReading = 0;
int LEDbrightness = 0;
int data = 0;
void setup(){
pinMode(13, OUTPUT);
Serial.begin(9600); // start serial for output
Wire.begin(SLAVE_ADDRESS); // initialize i2c as slave
// define callbacks for i2c communication
Wire.onReceive(receiveData);
Wire.onRequest(sendData);
Serial.println("Ready!");
void loop(){
photocellReading = analogRead(photocellPin);
LEDbrightness = map(photocellReading, 0, 1023, 0, 255);
Serial.println(LEDbrightness);
Serial.println(data);
sendData();
delay(1000);
void receiveData(int byteCount){ // callback for received data
while(Wire.available()){
number = Wire.read();
if (number == 1){
if (state == 0){
digitalWrite(13, HIGH); // set the LED on
state = 1;
else{
digitalWrite(13, LOW); // set the LED off
state = 0;
void sendData(){ // sending data to light the right led
if (LEDbrightness>=29 && LEDbrightness<=56){
data=128;
Wire.write(data);
goto end;
if (LEDbrightness>=57 && LEDbrightness<=84){
data=192;
Wire.write(data);
goto end;
if (LEDbrightness>=85 && LEDbrightness<=112){
data=224;
Wire.write(data);
goto end;
if (LEDbrightness>=113 && LEDbrightness<=140){
data=240;
Wire.write(data);
goto end;
if (LEDbrightness>=141 && LEDbrightness<=168){
data=248;
Wire.write(data);
goto end;
if (LEDbrightness>=167 && LEDbrightness<=196){
data=252;
Wire.write(data);
goto end;
if (LEDbrightness>=197 && LEDbrightness<=224){
data=254;
Wire.write(data);
goto end;
if (LEDbrightness>=225){
data=255;
Wire.write(data);
goto end;
end:{
Code on pi:
# -*- coding: utf-8 -*-
#!/usr/bin/env python
#pool automation
import smbus
import RPi.GPIO as GPIO
import time
import sys
import commands
import logging
import logging.handlers
sys.path.append('/Library_pyton/display_420/')
import RPi_I2C_driver
bus = smbus.SMBus(1) # for RPI version 1, use “bus = smbus.SMBus(0)”
arduino= 0x04 # This is the address we setup in the Arduino Program
lcd = RPi_I2C_driver.lcd()
SDI = 11 #DS
RCLK = 12 #ST
SRCLK = 13 #SH
relay1= 29 #pump slow speed
relay2= 31 #pump high speed
relay3= 32 #solar off
relay4= 33 #solar on
DATA = 0 #A on arduino
counterclockwise = 0 #open valve for solar panel
clockwise = 1 #close valve for solar panel
pump_status = "on" #default state for pump on 1st start
pump_speed = 'High' #default speed for pump on 1st start
WhichLeds = [0xff,0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00]
def setup():
GPIO.setmode(GPIO.BOARD) # Number GPIOs by its physical location
GPIO.setwarnings(False)
GPIO.setup(SDI, GPIO.OUT)
GPIO.setup(RCLK, GPIO.OUT)
GPIO.setup(SRCLK, GPIO.OUT)
GPIO.setup(relay1, GPIO.OUT)
GPIO.setup(relay2, GPIO.OUT)
GPIO.setup(relay3, GPIO.OUT)
GPIO.setup(relay4, GPIO.OUT)
GPIO.output(SDI, GPIO.LOW)
GPIO.output(RCLK, GPIO.LOW)
GPIO.output(SRCLK, GPIO.LOW)
GPIO.setup(relay1, GPIO.HIGH)
GPIO.setup(relay2, GPIO.HIGH)
GPIO.setup(relay3, GPIO.HIGH)
GPIO.setup(relay4, GPIO.HIGH)
def writeNumber(value):
bus.write_byte(arduino, value)
return -1
def readNumber():
number = bus.read_byte(arduino)
return number
def hc595_in(dat):
for bit in range(len(WhichLeds)-1, -1, -1):
GPIO.output(SDI, 0x80 & (dat << bit))
GPIO.output(SRCLK, GPIO.HIGH)
time.sleep(0.001)
def hc595_out():
GPIO.output(RCLK, GPIO.HIGH)
time.sleep(0.001)
def check_light():
global number
number = refresh()
if number >= 220 and clockwise == 1:
turnon_solar()
if number <= 50 and counterclockwise == 1:
turnoff_solar()
def refresh():
global number
hc595_in(number)
hc595_out()
lcd.lcd_display_string_pos('Light output ', 4, 0)
lcd.lcd_display_string_pos(str(readNumber()), 4, 13)
time.sleep(0.2)
return number
Thanks in advance for any help.... I was on a roll... Now I need help.
