Gryphon327
ActiveX workaround for printing
Thu Feb 04, 2016 8:03 pm
I am trying to find a way to print a label. The website (not within my control) uses PrintPipe (an ActiveX control) to print an HTML label. I would like to be able to do this from a Raspberry Pi 2. Is there any way to have the website call the AX control but instead run a script or other program to make it print? I don't have the option of not calling the AX control. I am willing to learn whatever language I need to make this work and I don't have a problem with cumbersome, off the wall solutions.
Navyscourge
Re: ActiveX workaround for printing
Sun Feb 07, 2016 9:02 pm
ActiveX is a Microsoft technology that runs on Windows systems in Internet Explorer and Office. I don't think that you will be able to run it on a Pi
Sun Feb 07, 2016 9:24 pm
This is a crappy workaround, but whether or not it will function is up to you to experiment:
http://pipelight.net/cms/plugin-npactivex.html
RPi 4B 4GB (SSD Boot)..
Gryphon327
Thu Feb 11, 2016 4:11 pm
Thank you for the suggestion fruitoftheloom. Unfortunately, I could not get pipelight to install and in the process had to reinstall the OS. Not sure what I did wrong to make that happen. I'll try it again from a fresh install and see if that helps.
