After mounting my USB hard drive and chmod'd the mounted folder to 775, I try to CD to it and depending on whether or not I use sudo, I get either permission denied or path not found. But yet I'm able to do an ls -l and see the contents of the HDD.
Here's the code I used to confirm what volumes are attached.
I'm hoping someone may be able to help me resolve this.
TIA!
pi@raspiHome:~ $ sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 14.9 GiB, 15931539456 bytes, 31116288 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xb3c5e39a
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 131071 122880 60M c W95 FAT32 (LBA)
/dev/mmcblk0p2 131072 31116287 30985216 14.8G 83 Linux
Disk /dev/sda: 1.8 TiB, 2000398931968 bytes, 3907029164 sectors
Disklabel type: dos
Disk identifier: 0xa4f3f7d1
/dev/sda1 * 2048 3907026943 3907024896 1.8T 7 HPFS/NTFS/exFAT
pi@raspiHome:~ $ sudo mount /dev/sda1 /mnt
pi@raspiHome:~ $ sudo chmod 775 /mnt
chmod: changing permissions of ‘/mnt’: Read-only file system
pi@raspiHome:~ $
pi@raspiHome:~ $ sudo ls -l /mnt
total 102420
dr-x------ 1 root root 4096 Jul 3 2013 home
dr-x------ 1 root root 8192 Jul 4 2013 lib
dr-x------ 1 root root 0 Sep 2 2012 local
-r-------- 1 root root 26 Dec 16 2012 lock
dr-x------ 1 root root 4096 Jan 31 14:21 log
-r-------- 1 root root 28 Jan 30 22:20 mail
dr-x------ 1 root root 0 Dec 15 2012 opt
dr-x------ 1 root root 0 Jun 9 2013 python_scripts
dr-x------ 1 root root 0 Jan 30 20:48 $RECYCLE.BIN
-r-------- 1 root root 16 Dec 16 2012 run
dr-x------ 1 root root 4096 Nov 25 2013 shares
dr-x------ 1 root root 0 Jun 6 2013 spool
-r-------- 1 root root 104857600 Dec 16 2012 swap
dr-x------ 1 root root 0 Jan 31 23:29 System Volume Information
dr-x------ 1 root root 0 May 31 2013 tmp
dr-x------ 1 root root 0 Jun 24 2013 www
pi@raspiHome:~ $
pi@raspiHome:~ $ cd /mnt
-bash: cd: /mnt: Permission denied
pi@raspiHome:~ $ sudo cd /mnt
sudo: cd: command not found
pi@raspiHome:~ $
