I have a raspberry pi2 with berryloader and micro sd Sandisk 16gb class10. I install Openelec and I have this problem after shut down my raspberry won't boot. I need to plug my sd card again and my raspberry boot ok. Can you help me with some information ?
Are you removing the SD card? It won't boot without the card, as that holds the Operating System and any files that you create. Leave it in.
When you have finished using the Pi, shut it down using the correct buttons, rather than just switching it off. The SD card might be corrupted if you just switch off.
