timmoore46
Size of various partitions on SD card
Sat Aug 04, 2012 11:13 am
I though fast and big is good, so I got a 16GB Class 10 SD card.
On using the Raspbian image for the first time, it asked me did I want to resize the root to use all the card. So I selected that and rebooted.
So now I'm very curious as to what size the Raspbian image normally comes out at ?
Also what is a neat way to view the size of the varoius partitions in Bash ? (is it Bash that is used as the CLI ? )
A very curious ,
:D :D :D
Tim
joan
Re: Size of various partitions on SD card
Sat Aug 04, 2012 11:43 am
Use the df command to have a look at the mount points, e.g.
joan@pluto:~$ df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 7.3G 3.0G 4.0G 44% /
/dev/root 7.3G 3.0G 4.0G 44% /
tmpfs 19M 216K 19M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 37M 0 37M 0% /tmp
tmpfs 10M 0 10M 0% /dev
tmpfs 37M 0 37M 0% /run/shm
/dev/mmcblk0p1 75M 35M 41M 46% /boot
/boot (sd card partition 1) is the WIndows FAT partition which is used during boot.
/dev/root is the Linux ext4 partition (sd card partition 2) which in your case has probably been expanded to 15+ Gigabytes.
(the tmpfs filesystems are RAM based for speed)
timmoore46
Sat Aug 04, 2012 12:29 pm
Many many thanks for the info.
Will try this out today !
a very happy,
:D :D :D :D :D :D
Tim
