Anyway....... When attempting to connect my laptop (purchased since the last time the RasPi was in service and has Win10) via SSH, it keeps telling me that it refused the key.
I used PuttyGen to generate a public/private key pair (RSA), copied the contents of the OpenSSH field into ~/.ssh/authorized_keys. I saved both the public key and the private key files on my laptop (not encrypted for now). Then I set Putty to use the private key file.
This is the contents of my authorized_keys file (yes it's all one line -- the website word-wrapped it):
ssh-rsa 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 rsa-key-20160130
This is my /etc/ssh/sshd_config file:
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
#Port 22
Port 9922
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
#PermitRootLogin yes
StrictModes yes
#RSAAuthentication yes
#PubkeyAuthentication yes
AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
# RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication. Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
#UsePAM no
PermitRootLogin no
AllowUsers pi
#AuthorizedKeysFile .ssh/authorized_keys
#PasswordAuthentication yes
