I'm on a fresh install of OSMC.
I try to launch Transmission after running (from the Programs menu), however it gives me the error: "Could not connect to Transmission. Open settings dialog?" I run this:
sudo systemctl status transmissionI have the defaults in host and port set, and then in user/pass I have the default "transmission/transmission".
I've installed Transmission successfully from the cmd prompt, but this appstore version is not working. Anyone know what might be the problem, or at least where to start troubleshooting?
