for those who are still interested in using both AD and DA (not at the same time) here is my code !!!
save this as my_lib.py
import time
import wiringpi as wp
def debug_print(string):
if False:
print("DEBUG: " + string)
class ADS1256:
""" Wiring Diagram
+-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | IN | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | IN | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 1 | 7 || 8 | 1 | ALT0 | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | ALT0 | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 1 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 1 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | ALT0 | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | ALT0 | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | ALT0 | 0 | 23 || 24 | 1 | OUT | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | OUT | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | IN | 1 | 27 || 28 | 1 | IN | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 1 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 1 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
| 13 | 23 | GPIO.23 | IN | 0 | 33 || 34 | | | 0v | | |
| 19 | 24 | GPIO.24 | IN | 0 | 35 || 36 | 0 | IN | GPIO.27 | 27 | 16 |
| 26 | 25 | GPIO.25 | IN | 0 | 37 || 38 | 0 | IN | GPIO.28 | 28 | 20 |
| | | 0v | | | 39 || 40 | 0 | IN | GPIO.29 | 29 | 21 |
# These options can be adjusted to facilitate specific operation of the
# ADS1256, the defaults are designed to be compatible with the Waveforms
# High Precision AD/DA board
SPI_MODE = 1
SPI_CHANNEL = 1
SPI_FREQUENCY = 1000000 # The ADS1256 supports 768kHz to 1.92MHz
DRDY_TIMEOUT = 0.5 # Seconds to wait for DRDY when communicating
DATA_TIMEOUT = 0.00001 # 10uS delay for sending data
SCLK_FREQUENCY = 7680000 # default clock rate is 7.68MHz
# The RPI GPIO to use for chip select and ready polling
CS_PIN = 15
DRDY_PIN = 11
RESET_PIN = 12
PDWN_PIN = 13
# Register addresses
REG_STATUS = 0x00
REG_MUX = 0x01
REG_ADCON = 0x02
REG_DRATE = 0x03
REG_IO = 0x04
REG_OFC0 = 0x05
REG_OFC1 = 0x06
REG_OFC2 = 0x07
REG_FSC0 = 0x08
REG_FSC1 = 0x09
REG_FSC2 = 0x0A
NUM_REG = 11
DRATE Register: A/D Data Rate Address 0x03 The 16 valid Data Rate settings are shown below. Make sure to select a
valid setting as the invalid settings may produce unpredictable results.
Bits 7-0 DR[7: 0]: Data Rate Setting(1)
11110000 = 30,000SPS (default)
11100000 = 15,000SPS
11010000 = 7,500SPS
11000000 = 3,750SPS
10110000 = 2,000SPS
10100001 = 1,000SPS
10010010 = 500SPS
10000010 = 100SPS
01110010 = 60SPS
01100011 = 50SPS
01010011 = 30SPS
01000011 = 25SPS
00110011 = 15SPS
00100011 = 10SPS
00010011 = 5SPS
00000011 = 2.5SPS
(1) for fCLKIN = 7.68MHz. Data rates scale linearly with fCLKIN
# sample rates
DRATE_30000 = 0b11110000 # 30,000SPS (default)
DRATE_15000 = 0b11100000 # 15,000SPS
DRATE_7500 = 0b11010000 # 7,500SPS
DRATE_3750 = 0b11000000 # 3,750SPS
DRATE_2000 = 0b10110000 # 2,000SPS
DRATE_1000 = 0b10100001 # 1,000SPS
DRATE_500 = 0b10010010 # 500SPS
DRATE_100 = 0b10000010 # 100SPS
DRATE_60 = 0b01110010 # 60SPS
DRATE_50 = 0b01100011 # 50SPS
DRATE_30 = 0b01010011 # 30SPS
DRATE_25 = 0b01000011 # 25SPS
DRATE_15 = 0b00110011 # 15SPS
DRATE_10 = 0b00100011 # 10SPS
DRATE_5 = 0b00010011 # 5SPS
DRATE_2_5 = 0b00000011 # 2.5SPS
# Commands
CMD_WAKEUP = 0x00 # Completes SYNC and exits standby mode
CMD_RDATA = 0x01 # Read data
CMD_RDATAC = 0x03 # Start read data continuously
CMD_SDATAC = 0x0F # Stop read data continuously
CMD_RREG = 0x10 # Read from register
CMD_WREG = 0x50 # Write to register
CMD_SELFCAL = 0xF0 # Offset and gain self-calibration
CMD_SELFOCAL= 0xF1 # Offset self-calibration
CMD_SELFGCAL= 0xF2 # Gain self-calibration
CMD_SYSOCAL = 0xF3 # System offset calibration
CMD_SYSGCAL = 0xF4 # System gain calibration
CMD_SYNC = 0xFC # Synchronize the A/D conversion
CMD_STANDBY = 0xFD # Begin standby mode
CMD_RESET = 0xFE # Reset to power-on values
Status Register Configuration - logically OR all desired options together
to form a 1 byte command and write it to the STATUS register
STATUS REGISTER - ADDRESS 0x00
Bits 7-4 ID3, ID2, ID1, ID0 Factory Programmed Identification Bits
(Read Only)
Bit 3 ORDER: Data Output Bit Order
0 = Most Significant Bit First (default)
1 = Least Significant Bit First
Input data is always shifted in most significant byte and bit first.
Output data is always shifted out most significant byte first. The
ORDER bit only controls the bit order of the output data within the
byte.
Bit 2 ACAL: Auto-Calibration
0 = Auto-Calibration Disabled (default)
1 = Auto-Calibration Enabled
When Auto-Calibration is enabled, self-calibration begins at the
completion of the WREG command that changes the PGA (bits 0-2 of ADCON
register), DR (bits 7-0 in the DRATE register) or BUFEN (bit 1 in the
STATUS register) values.
Bit 1 BUFEN: Analog Input Buffer Enable
0 = Buffer Disabled (default)
1 = Buffer Enabled
Bit 0 DRDY: Data Ready (Read Only)
This bit duplicates the state of the DRDY pin, which is inverted logic.
STATUS_BUFFER_ENABLE = 0x02
STATUS_AUTOCAL_ENABLE = 0x04
STATUS_ORDER_LSB = 0x08
A/D Control Register - Address 0x02
Bit 7 Reserved, always 0 (Read Only)
Bits 6-5 CLK1, CLK0: D0/CLKOUT Clock Out Rate Setting
00 = Clock Out OFF
01 = Clock Out Frequency = fCLKIN (default)
10 = Clock Out Frequency = fCLKIN/2
11 = Clock Out Frequency = fCLKIN/4
When not using CLKOUT, it is recommended that it be turned off. These
bits can only be reset using the RESET pin.
Bits 4-3 SDCS1, SCDS0: Sensor Detect Current Sources
00 = Sensor Detect OFF (default)
01 = Sensor Detect Current = 0.5uA
10 = Sensor Detect Current = 2uA
11 = Sensor Detect Current = 10uA
The Sensor Detect Current Sources can be activated to verify the
integrity of an external sensor supplying a signal to the ADS1255/6.
A shorted sensor produces a very small signal while an open-circuit
sensor produces a very large signal.
Bits 2-0 PGA2, PGA1, PGA0: Programmable Gain Amplifier Setting
000 = 1 (default)
001 = 2
010 = 4
011 = 8
100 = 16
101 = 32
110 = 64
111 = 64
# Gain levels
AD_GAIN_1 = 0x00
AD_GAIN_2 = 0x01
AD_GAIN_4 = 0x02
AD_GAIN_8 = 0x03
AD_GAIN_16 = 0x04
AD_GAIN_32 = 0x05
AD_GAIN_64 = 0x06
# Sensor Detect Current Sources
AD_SDCS_500pA = 0x08
AD_SDCS_2uA = 0x10
AD_SDCS_10uA = 0x18
# Clock divider
AD_CLK_EQUAL = 0x20
AD_CLK_HALF = 0x40
AD_CLK_FOURTH = 0x60
# Mux channel selection
MUX_AIN0 = 0x0
MUX_AIN1 = 0x1
MUX_AIN2 = 0x2
MUX_AIN3 = 0x3
MUX_AIN4 = 0x4
MUX_AIN5 = 0x5
MUX_AIN6 = 0x6
MUX_AIN7 = 0x7
MUX_AINCOM = 0x8
def __init__(self):
# Set up the wiringpi object to use physical pin numbers
wp.wiringPiSetupPhys()
# Initialize the DRDY pin
wp.pinMode(self.DRDY_PIN, wp.INPUT)
# Initialize the reset pin
wp.pinMode(self.RESET_PIN, wp.OUTPUT)
wp.digitalWrite(self.RESET_PIN, wp.HIGH)
# Initialize PDWN pin
wp.pinMode(self.PDWN_PIN, wp.OUTPUT)
wp.digitalWrite(self.PDWN_PIN, wp.HIGH)
# Initialize CS pin
wp.pinMode(self.CS_PIN, wp.OUTPUT)
wp.digitalWrite(self.CS_PIN, wp.HIGH)
# Initialize the wiringpi SPI setup
spi_success = wp.wiringPiSPISetupMode(self.SPI_CHANNEL, self.SPI_FREQUENCY, self.SPI_MODE)
debug_print("SPI success " + str(spi_success))
def delayMicroseconds(self, delayus):
wp.delayMicroseconds(delayus)
def chip_select(self):
wp.digitalWrite(self.CS_PIN, wp.LOW)
def chip_release(self):
def WaitDRDY(self):
Delays until DRDY line goes low, allowing for automatic calibration
start = time.time()
elapsed = time.time() - start
# Waits for DRDY to go to zero or TIMEOUT seconds to pass
drdy_level = wp.digitalRead(self.DRDY_PIN)
while (drdy_level == wp.HIGH) and (elapsed < self.DRDY_TIMEOUT):
if elapsed >= self.DRDY_TIMEOUT:
print("WaitDRDY() Timeout\r\n")
def SendString(self, mystring):
debug_print("Entered SendString: " + mystring)
result = wp.wiringPiSPIDataRW(self.SPI_CHANNEL, mystring)
debug_print("SendString read: " + str(result[1]))
def SendByte(self, mybyte):
Sends a byte to the SPI bus
debug_print("Entered SendByte")
debug_print("Sending: " + str(mybyte) + " (hex " + hex(mybyte) + ")")
mydata = chr(mybyte)
result = wp.wiringPiSPIDataRW(self.SPI_CHANNEL, "%s" % mydata) # notice workaround for single byte transfers JKR
debug_print("Read " + str(result[1]))
def ReadByte(self):
Reads a byte from the SPI bus
:returns: byte read from the bus
MISObyte = wp.wiringPiSPIDataRW(self.SPI_CHANNEL, chr(0xFF))
return ord(MISObyte[1]) #JKR
def DataDelay(self):
Delay from last SCLK edge to first SCLK rising edge
Master clock rate is typically 7.68MHz, this is adjustable through the
SCLK_FREQUENCY variable
Datasheet states that the delay between requesting data and reading the
bus must be minimum 50x SCLK period, this function reads data after
60 x SCLK period.
timeout = (60 / self.SCLK_FREQUENCY)
start = time.time()
# Wait for TIMEOUT to elapse
while elapsed < self.DATA_TIMEOUT:
def ReadReg(self, start_reg, num_to_read):
Read the provided register, implements:
RREG: Read from Registers
Description: Output the data from up to 11 registers starting with the
register address specified as part of the command. The number of
registers read will be one plus the second byte of the command. If the
count exceeds the remaining registers, the addresses will wrap back to
the beginning.
1st Command Byte: 0001 rrrr where rrrr is the address of the first
register to read.
2nd Command Byte: 0000 nnnn where nnnn is the number of bytes to read
1. See the Timing Characteristics for the required delay between the
end of the RREG command and the beginning of shifting data on DOUT: t6.
# Pull the SPI bus low
self.chip_select()
# Send the byte command
self.SendByte(self.CMD_RREG | start_reg)
self.SendByte(0x00)
# Wait for appropriate data delay
self.DataDelay()
# Read the register contents
read = self.ReadByte()
# Release the SPI bus
self.chip_release()
return read
def WriteReg(self, start_register, data):
Writes data to the register, implements:
WREG: Write to Register
Description: Write to the registers starting with the register
specified as part of the command. The number of registers that
will be written is one plus the value of the second byte in the
command.
1st Command Byte: 0101 rrrr where rrrr is the address to the first
register to be written.
2nd Command Byte: 0000 nnnn where nnnn is the number of bytes-1 to be
written
TODO: Implement multiple register write
# Select the ADS chip
self.chip_select()
# Tell the ADS chip which register to start writing at
self.SendByte(self.CMD_WREG | start_register)
# Tell the ADS chip how many additional registers to write
self.SendByte(0x00)
# Send the data
self.SendByte(data)
# Release the ADS chip
self.chip_release()
def ConfigADC(self):
debug_print("configuring ADC")
self.chip_select()
self.SendByte(self.CMD_WREG | 0x00) # start write at addr 0x00
self.SendByte(self.REG_DRATE) # end write at addr REG_DRATE
self.SendByte(self.STATUS_AUTOCAL_ENABLE) # status register
self.SendByte(0x08) # input channel parameters
self.SendByte(self.AD_GAIN_2) # ADCON control register, gain
self.SendByte(self.DRATE_500) # data rate
self.chip_release()
self.DataDelay()
def SetInputMux(self,possel,negsel):
debug_print("setting mux position")
self.chip_select()
self.SendByte(self.CMD_WREG | 0x01)
self.SendByte(0x00)
self.SendByte( (possel<<4) | (negsel<<0) )
self.chip_release()
def SyncAndWakeup(self):
debug_print("sync+wakeup")
self.chip_select()
self.SendByte(self.CMD_SYNC)
self.chip_release()
self.delayMicroseconds(10)
self.chip_select()
self.SendByte(self.CMD_WAKEUP)
self.chip_release()
def SetGPIOoutputs(self,D0,D1,D2,D3):
debug_print("set GPIO outputs")
IObits = D3*0x8 + D2*0x4 + D1*0x2 + D0*0x1
self.WriteReg(self.REG_IO,IObits)
def ReadADC(self):
Reads ADC data, implements:
RDATA: Read Data
Description: Issue this command after DRDY goes low to read a single
conversion result. After all 24 bits have been shifted out on DOUT,
DRDY goes high. It is not necessary to read back all 24 bits, but DRDY
will then not return high until new data is being updated. See the
Timing Characteristics for the required delay between the end of the
RDATA command and the beginning of shifting data on DOUT: t6
self.chip_select()
# Wait for data to be ready
self.WaitDRDY()
# Send the read command
self.SendByte(self.CMD_RDATA)
# Wait through the data pause
self.DataDelay()
# The result is 24 bits
#result.append(self.ReadByte())
result1 = self.ReadByte()
result2 = self.ReadByte()
result3 = self.ReadByte()
debug_print('ReadADC result bytes: ' + hex(result1) + ' ' + hex(result2) + ' ' + hex(result3))
self.chip_release()
# Concatenate the bytes
total = (result1 << 16) + (result2 << 8) + result3
return total
def ReadID(self):
Read the ID from the ADS chip
:returns: numeric identifier of the ADS chip
self.WaitDRDY()
myid = self.ReadReg(self.REG_STATUS, 1)
debug_print("readID: myid = " + str(myid>>4))
return (myid >> 4)
and here my code that does some stuff (reading temperature, reading ad, setting da, getting tcp command, sending telegram message checking mysql database for some other stuff saving data to mysql (not gonna give mysql functions))
its up to you guys to do the configuration to the way you want !!!
it read 4 differential analog data so i am using all inputs!!!
you have to do the libbcm2835 configurations !!!
python 2.7 !!!
import libbcm2835._bcm2835 as soc
import my_lib
import select
import sys
import time
import datetime
import threading
import socket
import telepot
import numpy as np
import matplotlib.pyplot as plt
import chart_functions_d as cf
import mysql_data_save as mysql
import os
import glob
ads = my_lib.ADS1256()
idNumber = ads.ReadID()
print("\nADS1256 reported ID value: {}".format(idNumber))
SPICS = 23
control_pin=20
channel_A = 0x30
channel_B = 0x34
read_am=1500
tim = []
ad0 = []
ad1 = []
ad2 = []
ad3 = []
def temperature_1():
file = open('/sys/bus/w1/devices/10-000000084899/w1_slave')
filecontent = file.read()
file.close()
stringvalue = filecontent.split("\n")[1].split(" ")[9]
temperature = float(stringvalue[2:]) / 1000
t_1 = '%6.2f' % temperature
return(t_1)
def Voltage_Convert(Vref,voltage):
_D_=(65536*voltage/Vref)
return (_D_)
def Write_DAC8532(channel, Data):
Data = int(Data)
soc.bcm2835_gpio_write(SPICS,1)
soc.bcm2835_gpio_write(SPICS,0)
soc.bcm2835_spi_transfer(channel)
soc.bcm2835_spi_transfer((Data>>8))
soc.bcm2835_spi_transfer((Data&0xff))
def send_text(msg):
try:
bot = telepot.Bot(token=" ")
chat_id = " "
command = msg
bot.sendMessage(chat_id, text=command)
print("send text")
except Exception,ex:
print(str(ex))
def connect_as_reciever():
ar0=[]
ar1=[]
d_t=[]
count=0
while True:
try:
TCP_PORT = 5555
BUFFER_SIZE = 1024
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
s.bind(('', TCP_PORT))
s.listen(1)
while 1:
try:
conn, addr = s.accept()
data = conn.recv(BUFFER_SIZE)
if data =="":
print("nothing from tcp")
conn.close()
elif data=="read":
read_ad()
s_data="Read all AD"
conn.send(s_data)
else:
Write_DAC8532(0x30, Voltage_Convert(5.0,0.0+float(data)/1000))
#set_value(data)
data2 = "DA is set"
conn.send(data2)
except Exception ,ex:
#print("ER - 1 :",ex)
conn.close()
#break
a=2
#print("ER -2 :",ex)
def read_ad():
try:
temp1=0
c=0
d=0
volt=0
amper=0
ft = time.time()
ads.SetInputMux(ads.MUX_AIN3, ads.MUX_AIN7)
time.sleep(0.05)
volt=ads.ReadADC()
ads.SetInputMux(ads.MUX_AIN0, ads.MUX_AIN4)
time.sleep(0.05)
while 1:
time.sleep(0.0001)
ad0.append(ads.ReadADC())
tim.append(datetime.datetime.now())
ad1.append(0)
ad2.append(0)
ad3.append(0)
c=c+1
d=d+1
if c==read_am:
ads.SetInputMux(ads.MUX_AIN1, ads.MUX_AIN5)
time.sleep(0.05)
c=0
while 1:
time.sleep(0.0001)
ad1.append(ads.ReadADC())
ad0.append(0)
ad2.append(0)
ad3.append(0)
c=c+1
d=d+1
if c==read_am:
ads.SetInputMux(ads.MUX_AIN2, ads.MUX_AIN6)
time.sleep(0.05)
c=0
while 1:
time.sleep(0.0001)
ad2.append(ads.ReadADC())
ad0.append(0)
ad1.append(0)
ad3.append(0)
c=c+1
d=d+1
if c==read_am:
time.sleep(0.05)
c=0
while 1:
time.sleep(0.0001)
ad3.append(ads.ReadADC())
ad0.append(0)
ad1.append(0)
ad2.append(0)
c=c+1
d=d+1
if c==read_am:
temp1=temperature_1()
temp1_date=datetime.datetime.now()
time.sleep(0.05)
c=0
break
break
break
break
if float(d)>100000:
print("too much data for chart it will crash skipping chart show")
else:
copy_0=ad0[:]
copy_1=ad1[:]
copy_2=ad2[:]
copy_3=ad3[:]
copy_t=tim[:]
copy_tmp=temp1
copy_tmp_date=temp1_date
d_val,cdis=mysql.chck_da_is_set()
if cdis=='1':
Write_DAC8532(0x30, Voltage_Convert(5.0,0.0+float(d_val)/1000))
mysql.update_da_is_set()
#cf.show_chart(ad0,ad1,ad2,ad3,tim)
mysql.write_to_db(copy_0,copy_1,copy_2,copy_3,copy_t,copy_tmp,copy_tmp_date)
del tim [:]
del ad0 [:]
del ad1 [:]
del ad2 [:]
del ad3 [:]
d=0
c=0
except Exception, ex:
send_text("Error from Raspi 15 : " + str(ex))
print("er at read_0"+str(ex))
if not soc.bcm2835_init():
print ("noit")
else:
soc.bcm2835_spi_begin()
soc.bcm2835_spi_setBitOrder(soc.BCM2835_SPI_BIT_ORDER_LSBFIRST )
soc.bcm2835_spi_setDataMode(soc.BCM2835_SPI_MODE1)
soc.bcm2835_spi_setClockDivider(soc.BCM2835_SPI_CLOCK_DIVIDER_1024)
soc.bcm2835_gpio_fsel(SPICS, soc.BCM2835_GPIO_FSEL_OUTP)
soc.bcm2835_gpio_fsel(control_pin, soc.BCM2835_GPIO_FSEL_INPT)
soc.bcm2835_gpio_write(SPICS, 0)
while True:
read_ad()
#connect_as_reciever()
I am the terror that flaps in the night...
I am the surprise you find in your cereal box!
I am DARKWING DUCK!!!
