iNeedsHelp
PuTTY over ethernet problem.
Tue Jan 26, 2016 7:42 pm
Ok, so I am using an Ethernet to Ethernet cable, and I have downloaded PuTTY and found my Pi's IP address, but when I clicked "Open" this came up, and it wont let me type, am I supposed to reconfigure my computers address or something?
I got this thing for Christmas last year, but every time I try to boot it, it doesn't work, Please Help!!
DirkS
Re: iNeedsHelp!
Tue Jan 26, 2016 7:49 pm
iNeedsHelp wrote:Ok, so I am using an Ethernet to Ethernet cable, and I have downloaded PuTTY and found my Pi's IP address, but when I clicked "Open" this came up, and it wont let me type, am I supposed to reconfigure my computers address or something?
What does 'this came up' mean?
Without a proper topic title and hardly any information to go on it's unlikely to get your problem solved...
See https://www.raspberrypi.org/documentati ... windows.md for accessing your Pi with Putty
B.Goode
Re: iNeedsHelp!
Tue Jan 26, 2016 8:43 pm
iNeedsHelp wrote:every time I try to boot it, it doesn't work
If it doesn't work then it can't have an IP address and you can't possibly hope to connect to it with PuTTY.
I connect to all sorts of model of RPi running the Raspbian Operating System all the time, there's no magic trick.
I suggest you calmly describe what you have tried, how it seems to fail, and what assistance you need.
PS: a follow-up having read your similar query from earlier today... Can you confirm that you have actually installed an Operating System on your RPi. NOOBS is only an Installer - you can't usefully connect to it with PuTTY.
saifsmailbox98
Re: iNeedsHelp!
Tue Jan 26, 2016 8:54 pm
Try connect it to a monitor and get it working. Then check the IP.
Try this guide to get your IP address:
http://www.wikihow.com/Check-the-IP-Address-in-Linux
Make sure the Raspberry Pi is connected properly to the network.
If nothing works try reinstalling the OS.(I don't think you would need to do this)
Let me know what do you mean by "this"?
Kindness is a mark of faith, and whoever is not kind has no faith. -Messenger of God
iNeedsHelp
Re: iNeedsHelp!
Wed Jan 27, 2016 4:24 pm
saifsmailbox98 wrote:Try connect it to a monitor and get it working. Then check the IP.
I was attempting to give a screen shot of what happened, but it wouldn't load for the attachments section
DirkS
Re: iNeedsHelp!
Wed Jan 27, 2016 4:25 pm
iNeedsHelp wrote:I was attempting to give a screen shot of what happened, but it wouldn't load for the attachments section
Upload it to a (free) image hosting site post a link here.
rurwin
Re: PuTTY over ethernet problem.
Wed Jan 27, 2016 5:01 pm
Don't use NOOBS. I think that might require you to have a monitor. Use Raspbian. I've gone through this very process this afternoon and it worked perfectly.
Connect the Pi to your router with an ethernet cable.
Tell us how you are finding the IP address, because I'm not sure you are doing it right.
iCantThinkOfAnythint
Wed Jan 27, 2016 6:49 pm
rurwin wrote:Don't use NOOBS. I think that might require you to have a monitor. Use Raspbian. I've gone through this very process this afternoon and it worked perfectly.
I'm his brother, and I'm working with him on this
We are using the app "Fing" like you told him to use
rurwin
Wed Jan 27, 2016 6:53 pm
Good. So when you use Fing, touch the listing of the Raspberry Pi. That will take you to a new page. Then touch "Scan services" and tell us what it says.
Wed Jan 27, 2016 6:56 pm
also, sir, please tell me, which raspbian should I use? There's like Jesse, and wheezy
And can I have a tutorial to help install it?
I've tried, and it didn't seem to install right
Wed Jan 27, 2016 7:02 pm
just an IP address, and underneath it says generic
Wed Jan 27, 2016 7:06 pm
rurwin wrote:Good. So when you use Fing, touch the listing of the Raspberry Pi. That will take you to a new page. Then touch "Scan services" and tell us what it says.
Do I need the SD car for raspbian?
DirkS
Wed Jan 27, 2016 7:23 pm
iCantThinkOfAnythint wrote:also, sir, please tell me, which raspbian should I use? There's like Jesse, and wheezy
Raspbian Jessie: https://www.raspberrypi.org/downloads/raspbian/
You will need an SD card (minimum 8GB)
Instructions follow the link on the download page: https://www.raspberrypi.org/documentati ... /README.md
Wed Jan 27, 2016 8:02 pm
Ok thanks, do I need to get NOOBS off the SD card?
DirkS
Wed Jan 27, 2016 8:07 pm
iCantThinkOfAnythint wrote:Ok thanks, do I need to get NOOBS off the SD card?
No, if you write the Raspbian image to the card it will be overwritten anyway
rurwin
Wed Jan 27, 2016 8:42 pm
This is what Fing looks like on my network:
There's loads of devices there: a few phones, a Mac, my Linux desktop, the printer, the Sky box, etc., etc.
Notice the highlighted entry though is a (fairly) new Raspbian install. You can tell it is a Pi because it's labelled as "Raspberry Pi Foundation". "vesta" is the computer name, so yours will be different.
Here is what happens when I select that and touch "Scan Services".
So are you saying that you don't have any services listed (like "SSH" in this picture)?
Wed Jan 27, 2016 9:04 pm
So I just did the raspbian thing, and a new thing popped up on the app
"22 SSH Secure Shell Login"
I also just did "Open" and it works, now it says "login as"
And I typed in raspberry,
Then it said "password" or whatever
I typed in "pi" and it said access denied
Wed Jan 27, 2016 9:15 pm
Try doing it the other way round. ID==pi, PASSWORD==raspberry
Navyscourge
Wed Jan 27, 2016 9:16 pm
Login as pi
Password is raspberry
Wed Jan 27, 2016 9:23 pm
Ok, it now says pi@raspberry: ~ $
B.Goode
Wed Jan 27, 2016 9:27 pm
Job done. You have now booted your RPi using Raspbian and logged into it with PuTTY.
Wed Jan 27, 2016 9:32 pm
B.Goode wrote:Job done. You have now booted your RPi using Raspbian and logged into it with PuTTY.
Ok thanks, but now how do I "start" it? Cause I'm seeing all these picture of this like Microsoft word type thing, but for the raspberry Pi
JimmyN
Wed Jan 27, 2016 9:40 pm
If by "start it" you mean a desktop you can't do that over Putty, it's just a terminal. The desktop is likely running, but you'll need to plug the Pi into a monitor or TV to see it. Or use some remote desktop software so you can see the desktop on your PC.
Wed Jan 27, 2016 9:43 pm
the terminal with (what I can think of off the top of my head) minecraft Pi edition
Wed Jan 27, 2016 9:44 pm
JimmyN wrote:If by "start it" you mean a desktop you can't do that over Putty, it's just a terminal. The desktop is likely running, but you'll need to plug the Pi into a monitor or TV to see it. Or use some remote desktop software so you can see the desktop on your PC.
What software would you recommend?
