raspberrypiAndMe
Raspbmc + HDMI + standard 3.5mm jack (AUX)
Fri Aug 03, 2012 4:49 pm
Hi there,
I hope someone can help me out.
Actual condition:
- got my raspbmc up and running
- everything is fine, streaming movies with sound over HDMI to my TV
- Airplay works fine with my Android Device
I guess it's not really possible, but... :roll:
do you think there is a way to output the sound over HDMI and the standard 3.5mm jack (at the same time)?
The reason why I want to do this:
Without having the TV on, streaming music from my Android to my HiFi system.
norp
Re: Raspbmc + HDMI + standard 3.5mm jack (AUX)
Sat Aug 04, 2012 2:16 pm
Wanted to do the same
Apparently the sound driver (alsa) is too alpha right now for dual audio.
What would work is if xbmc actually allowed to seperately set different audio device for movies and music; this won't need a proper driver support, just a small (?) software rewrite.
Unfortunately I don't have enough time to delve into the depth of the xbmc source code and this request has been queuing for ages (just check out the xbmc forums)
raspberrypiAndMe
Thu Sep 06, 2012 4:23 pm
Hi norp,
unfortunately I also got no time to rewrite the driver and also got no experience with it.
Is there something new going on?
captainzoom
Mon Oct 15, 2012 6:54 pm
If this were possible it would be great for the same reason as stated by OP.
Zlad
Wed Dec 19, 2012 8:06 am
Can I ask how to set the aux > hdmi as sound? I need to do this because of the way my surround sound is set up.
captainzoom
Wed Dec 19, 2012 11:16 am
Go to settings -> system -> audio -> output.
niomix
Mon Jan 07, 2013 9:59 am
Hi to all, i've the same problem.
Someone solve he issue using this patch... but is't for windows only !
http://forum.xbmc.org/showthread.php?tid=86038
any new idea ?
adamdbz
Thu Feb 14, 2013 3:30 pm
Any update i would love to use them both too. :D
adrianzhang
Sat Jan 11, 2014 10:53 am
This was solved in the newest version RaspBMC (based on my reply time), I did something and sound go out from both HDMI and 3.5mm jack.
niomix
Sat Jan 11, 2014 4:19 pm
yes but with a big unmodifiable delay betweek two channels :(
You can't use both at the same time yet.
adrianzhang
Mon Jan 13, 2014 10:10 am
niomix wrote:yes but with a big unmodifiable delay betweek two channels :(
Are you replying to me? I didn't meet similar issue, sound syncs of HDMI and Stereo on my RaspBMC system.
BTW, based on my experience, this was solved by newest RaspBMC, with some configs users are able to hear sound from both HDMI and 3.5mm jack.
However, that doesn't realize on my Raspbia+XBMC(which installed by following this post: http://michael.gorven.za.net/raspberrypi/xbmc
Return to “Media centres”
