I've written a simple python GUI which uses data from a micrometer based on a script Joan wrote in this thread using PIGPIOD:
viewtopic.php?p=830514#p830514
If I boot up my Pi and run my script, it doesn't work as it should. It is supposed to display a value which is read from the micrometer but instead it displays a blank value.
BUT if I run Joan's original script, close it, and run my script, it works perfectly.
I really can't work out what's going on here, any ideas?
Joans original reader script:
import time
import pigpio
CLOCK=21
DATA=20
g_level=0
g_reading=0
g_bits=0
def show(bits, value):
inch = value & (1<<23)
minus = value & (1<<20)
value = value & 0xfffff
if inch:
reading = value / 2000.0
units = "in"
else:
reading = value / 100.0
units = "mm"
if minus:
sign = "-"
else:
sign = ""
print("{} {:.3f} {}".format(sign, reading, units))
def cbf(g, l, t):
global g_level, g_reading, g_bits
if g == DATA:
if l == 0:
g_level = 1
else:
g_level = 0
elif g == CLOCK:
if l == pigpio.TIMEOUT:
if g_bits > 10:
show(g_bits, g_reading)
g_reading=0
g_bits=0
elif l == 0:
g_reading = g_reading | (g_level<<g_bits)
g_bits += 1
pi = pigpio.pi()
pi.set_mode(CLOCK, pigpio.INPUT)
pi.set_mode(DATA, pigpio.INPUT)
cb1 = pi.callback(DATA, pigpio.EITHER_EDGE, cbf)
cb2 = pi.callback(CLOCK, pigpio.EITHER_EDGE, cbf)
pi.set_watchdog(CLOCK, 20) # 20 ms reading timeout
time.sleep(120)
cb2.cancel()
cb1.cancel()
pi.stop()
import datetime
import csv
from tkinter import *
from tkinter import messagebox
import time
import pigpio
import os
os.system("sudo pigpiod")
root = Tk()
winx = 480
winy = 320
CLOCK=21
DATA=20
g_level=0
g_reading=0
g_bits=0
pi = pigpio.pi()
pi.set_mode(CLOCK, pigpio.INPUT) #sets clock as input
pi.set_mode(DATA, pigpio.INPUT) #sets data as input
virtual_reading = StringVar()
def go():
global cb1
global cb2
if inch:
units = "in"
else:
units = "mm"
if minus:
sign = "-"
else:
sign = ""
virtual_reading.set("{} {:.3f} {}".format(sign, reading, units))
print(virtual_reading.get())
def measure(event=None):
todays_date = datetime.date.today()
try:
get_tool_no = int(tool_no_entry.get())
if get_tool_no <= 0:
messagebox.showerror("Try Again","Please Enter A Number")
else:
with open("thickness records.csv", "a") as thicknessdb:
thicknessdbWriter = csv.writer(thicknessdb, dialect='excel', lineterminator='\r')
thicknessdbWriter.writerow([get_tool_no] + [todays_date] + [virtual_reading.get()])
thicknessdb.close()
except:
tool_no_entry.delete(0, END)
def cbf(g, l, t):
if g == DATA:
if l == 0:
g_level = 1
else:
g_level = 0
elif g == CLOCK:
if g_bits > 10:
g_reading=0
g_bits=0
elif l == 0:
g_bits += 1
go()
record_button = Button(root,width = 30,
height = 8,
text='Measure',
fg='black',
bg="light grey", command = measure)
tool_no_entry = Entry(root)
reading_display = Label(root, font=("Helvetica", 22), textvariable = virtual_reading)
reading_display.place(x = 50, y =80)
root.resizable(width=FALSE, height=FALSE)
root.geometry('%dx%d' % (winx,winy))
root.title("Micrometer Reader V1.0")
record_button.place(x = 340, y = 100, anchor = CENTER)
tool_no_entry.place(x = 120, y = 250, anchor=CENTER)
tool_no_entry.focus_set()
root.bind("<Return>", measure)
root.mainloop()
cb2.cancel()
cb1.cancel()
pi.stop()
