JonnyAlpha
Raspberry Pi Certified Educator
GPIO protection - resistor values
Sun Jan 17, 2016 9:26 am
Hi;
Can anyone confirm what size resistors I should be using to protect the GPIO or is it dependent upon the rest of the circuit?
Some examples are:
1. Values for pull up resistors when connected to 3.3v?
2. Resistors connected between LED and Gnd?
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
joan
Re: GPIO protection - resistor values
Sun Jan 17, 2016 11:21 am
I have no electronics knowledge. From what I've seen on the forum.
1. The internal pull-ups/downs are circa 50k. I suggest something in the 5-20k range for external. I suppose it's best to use the highest value which works.
2. Depends on how bright you want your LEDs (modern ones seem too bright at maximum mA). I suggest something in the 330-1000 range. Suck it and see I'm afraid.
rpdom
Sun Jan 17, 2016 11:35 am
People generally use 10K resistors for external pull-up/down as they are a very common value that most hobbyists have in their collection. It is worth getting a pack of those, and also 1K resistors, which can be used to protect the GPIO from overload if the GPIO is accidentally set as output while connected to ground or +V.
mikronauts
Sun Jan 17, 2016 9:51 pm
what they said :)
I normally use:
10k for pullups or pulldowns
470R for LED's
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
Return to “Advanced users”
