Batboat
Lirc trouble on ra-pi 2, model B, rev. 1.1
Sat Jan 16, 2016 8:49 pm
I wanna be able to receive, record and send signals using lirc. I have weird problems. Hope someone may be able to help me
I have installed raspberian including lirc. This version had many issues on the licr 0.9.0 so now I have installed lirc 0.9.3a. That did change something. Now I was able to use mode2 (receive IR) and I saw it on screen.
I have NO problem restarting (reinstalling server) and follow a guide that would work, please help (Obi-Wan Kenobi you are my only hope)
Here are some facts!
When I run "lircd" it outputs this:
lircd: can't open or create /var/run/lirc/lircd.pid
lircd: No such file or directory
When I do: "irsend SEND_ONCE denon KEY_VOLUMEUP" it outputs:
do_connect: could not connect to socket
connect: No such file or directory
irsend: could not open socket: No such file or directory
Here are some "facts" of what I have done...
"dmesg | grep lirc" outputs this
[3.675699] lirc_dev: IR Remote Control driver registered, major 245
[4.585786] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[5.545997] lirc_rpi: auto-detected active low receiver on GPIO pin 18
[5.546357] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[5.546371] lirc_rpi: driver registered!
"mode2" outputs this
Using device: /dev/lirc0
Warning: Running as root. (red. yeah I know.........)
/etc/modules looks like this
i2c-dev
lirc_dev
lirc_rpi gpio_in_pin=18 gpio_out_pin=17
/etc/hardware.conf looks like this
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS=""
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="default"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="lirc_rpi"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
In the end of /boot/config I have added this:
dtoverlay=lirc-rpi,gpio_in_pin=18,gpio_out_pin=17
"uname -a! gives this
Linux raspberrypi 4.1.15-v7+ #830 SMP Tue Dec 15 17:02:45 GMT 2015 armv7l GNU/Linux
my /etc/lircd.conf looks like this
# Please make this file available to others
# by sending it to <lirc@bartelmus.de>
# this config file was automatically generated
# using lirc-0.9.0-pre1(default) on Fri Jan 15 01:37:58 2016
# contributed by
# brand:                       /root/lircd.conf
# model no. of remote control:
# devices being controlled by this remote:
begin remote
  #name  /root/lircd.conf
  name  denon
  bits           24
  flags SPACE_ENC
  eps            30
  aeps          100
  header       3389  1715
  one           390  1293
  zero          390   451
  ptrail        390
  pre_data_bits   24
  pre_data       0x2A4C0A
  gap          74623
  min_repeat      5
#  suppress_repeat 5
#  uncomment to suppress unwanted repeats
  toggle_bit_mask 0xC000C
      begin codes
          KEY_POWER                0x8C0284
          KEY_VOLUMEUP             0x82028A
      end codes
end remote
noamshemesh
Re: Lirc trouble on ra-pi 2, model B, rev. 1.1
Sat Jan 30, 2016 12:08 pm
I'm experiencing the same issue, and I use an usb transceiver.
I'll update if I find anything new
