annlee
Need to fix rpi networks problem for $15-$20
Sat Jan 16, 2016 4:37 pm
I failed to find someone to help me at fiverr.com with this issue:
I got a raspberry pi (linux distro called "DietPi" based on Debian Jessie) which provides a WIFI access point via a WIFI dongle to an App that connects and gets data via FTP and also provides internet access to the App if the ethernet is plugged, this works, but got 2 problems:
1º) the DHCP server makes a long loop (about 1:30 minutes) when the ethernet cable is unplugged (like this https://bugs.debian.org/cgi-bin/bugrepo ... bug=754218) I would like to boot fast in the case the ethernet is unplugged
2º) the raspberry pi used to have internet access by itself when ehternet is plugged, but I should have touched something in interfaces and does not work now: this should be a simple fix
I can provide you any files and make all the changes you need, I consider time is money so I can pay $15-$20 for this (paypal), is there anyone interested? ty~
fourdee4d
Re: Need to fix rpi networks problem for $15-$20
Sat Jan 16, 2016 5:39 pm
annlee wrote:I failed to find someone to help me at fiverr.com with this issue:
Hi Annlee,
Please send a DietPi Bugreport which will contain your system configuration/settings. I will then look into your query and should be able to assist you:
dietpi-bugreport
I will need to Reference Code which is generated when you send the bugreport. Please post this in your reply.
ps. DietPi doesn't charge for support, all funding is obtained through donations.
Regards,
Dan
DietPi.com - Lightweight justice for your Raspberry Pi. Optimized, simplified linux for everyone
DietPi's web hosting is powered by MyVirtualServer.com
annlee
Sat Jan 16, 2016 5:52 pm
Hi Annlee,
dietpi-bugreport
Regards,
Dan
thanks a lot but cannot send it since the rpi itself does not have internet (2nd issue I mention)
I generated the offline report and sent you a PM :) after this imma donate
annlee
Sun Jan 17, 2016 7:32 pm
for those who could suffer from this :lol:
here comes the fix for both problems:
- add into interfaces the line:
bridge_maxwait 5
this will break the long loop
- do your ethernet with dhcp and type
dhclient eth0
