haylocki
Python Bluetooth advertise_service error
Wed Jan 13, 2016 1:02 pm
I recently installed minibian on my Raspberry Pi model B.
When running a python program I received the following error:
Process Process-2:
File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
self.run()
File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
self._target(*self._args, **self._kwargs)
File "/root/my_bluetooth.py", line 91, in server
profiles = [ SERIAL_PORT_PROFILE ],
File "/usr/lib/python2.7/dist-packages/bluetooth/bluez.py", line 176, in advertise_service
raise BluetoothError (str (e))
BluetoothError: (2, 'No such file or directory')
After many hours of Googling, I finally found the solution in a Fedora bug report.
To fix the error :
Edit "/lib/systemd/system/bluetooth.service"
and change the line :
ExecStart=/usr/lib/bluetooth/bluetoothd
To :
ExecStart=/usr/lib/bluetooth/bluetoothd --compat
Hopefully someone will find this helpful.
Cheers, Ian
oferby
Re: Python Bluetooth advertise_service error
Wed Oct 05, 2016 1:08 pm
Thank!!!!
it did the trick.
Ofer.
