I just want to share my super simple DIY enclosure. I managed to modify the packaging of a 67mm Sky filter to house my raspberryPi. The length of the board fits nearly perfect, so all I had to do was opening up the sides to make the overlapping connectors come out. As I'm not planning to use HDMI (as of yet), I didn't opened the backside of the case. However, this addition is definitely possible without too much of a hassle...
A few notes on working with the material (PS == Polystyrene): The material is very brittle, so I needed to be very careful not to break anything inadvertently!!!
I mainly used a hacksaw blade, a drill and a triangular file. For rectangular notches (USB, Ethernet,...) I just made two vertical cuts and carefully broke the plastic at the edge. Smoothing the edge with the file -> done.
For holes (power, audio, ...) I used a small drill (the only one I had
Here is the final result \o/ Let me know, what you think of it and what you would do with the space left?
I, for one, don't miss the feeling of almost breaking things of the board when working on the connectors...
