Agentwright
Got a PI Zero! want wifi
Wed Jan 13, 2016 4:43 am
Hello all, This is my first post, I have a TON to learn. I am brand new to computers and programming. My question is, what is the easiest/best way to manage the single USB port. I have a wireless keyboard/mouse.. and I have a usb wifi adapter.. but I only have one usb port on the Zero... so what is the solution? thanks
Re: Got a PI Zero! want wifi
Wed Jan 13, 2016 8:10 am
Agentwright wrote:Hello all, This is my first post, I have a TON to learn. I am brand new to computers and programming. My question is, what is the easiest/best way to manage the single USB port. I have a wireless keyboard/mouse.. and I have a usb wifi adapter.. but I only have one usb port on the Zero... so what is the solution? thanks
Mains Powered USB 2.0 Hub ;)
Retired disgracefully.....
hansotten
Wed Jan 13, 2016 8:38 am
Most simple hubs will do. Powered is nice, I have found it to be overkill on a Zero.
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
Wed Jan 13, 2016 8:40 am
hansotten wrote:Most simple hubs will do. Powered is nice, I have found it to be overkill on a Zero.
Mains Powered Hub is good as negates the need for a PSU, but each to their own :D
RaTTuS
Contact: Twitter YouTube
Wed Jan 13, 2016 8:43 am
^ this
a mains powered USB HUB [with inbuilt Ethernet for added usefulness] one plug = extra ports and power
Covfefe
PiGraham
Wed Jan 13, 2016 9:03 am
These hubs work nicely with Pi Zero and cost less than the Pi.
http://www.amazon.co.uk/gp/product/B00O ... ge_o00_s00
Micro USB to plug into Pi.
Micro USB socket for power in.
3 USB A sockets for mouse, keyboard & WiFi (or whatever)
You can use the micro USB socket for another USB device if put power into the Pi and have the right connector / adaptor. It is a four port hub.
Wed Jan 13, 2016 9:22 am
^ this
Unfortunately many Ethernet use the DCM9601 or ASIX AX88772 Chipset which appear from various posts to be troublesome..
Last edited by fruitoftheloom on Wed Jan 13, 2016 9:53 am, edited 1 time in total.
scotty101
Wed Jan 13, 2016 9:28 am
fruitoftheloom wrote: Unfortunately many Ethernet use the DCM9601 or ASIX78xx Chipset which appear from various posts to be troublesome..
I'm pretty sure that's been my problem. I bought a USB hub + ethernet port from eBay and it causes a kernel panic when you try use the internet.
I hadn't seen any posts about other people having the same problem. Do you have a link?
DirkS
Wed Jan 13, 2016 9:35 am
Tempted to use LMGTFY... ;)
viewtopic.php?f=28&t=131169#p875055
Wed Jan 13, 2016 9:40 am
viewtopic.php?f=28&t=131211
Last edited by fruitoftheloom on Wed Jan 13, 2016 9:56 am, edited 1 time in total.
RaTTuS
Wed Jan 13, 2016 9:47 am
aha yes - I do have a DCM9601 that seems to crash the RPi
Covfefe
scotty101
Wed Jan 13, 2016 10:27 am
Aside from Dirk's LMGTFY comment, thanks all.
I had searched for it but obviously not the right search terms.
Wed Jan 13, 2016 11:00 am
scotty101 wrote:Aside from Dirk's LMGTFY comment, thanks all.
The Realtek RTL8152 Chipset seems a good choice, it is used by Google ChromeCast "Ethernet over USB" Adaptor:
Not bad price for quality £12.00: http://www.amazon.co.uk/dp/B00WR6A57S
PiGraham
Wed Jan 13, 2016 3:43 pm
Some good advice there, but remember the OP only asked about connecting his existing WiFi adaptor and Keyboard/mouse.
Massi
Wed Jan 13, 2016 4:00 pm
PiGraham wrote:These hubs work nicely with Pi Zero and cost less than the Pi.
i think that this is not going to power both your pi and your usb attached devices..
W. H. Heydt
Wed Jan 13, 2016 5:10 pm
Frankly...if you're that new to working with computers and programming, and especially being new to single board computers (SBCs), I would recommend setting the Pi Zero aside and getting a Pi2B, or a Model B+. Once you have established a comfort level with one of those boards, then take up the Pi Zero again for projects suited to it.
PiGraham
Thu Jan 14, 2016 9:52 am
You can use the micro USB socket for another USB device if put power into the Pi and have the right connector / adaptor. It is a three yuport hub.
It may depend what device you have. For the OP with WiFi, Keyboard/mouse it's OK. I have one doing that.
External hard disk not so good.
If you need something beefy pay more and get a big desktop hub. If you just need the basics for Pi0 money and size this is a good option. It does the job.
Thu Jan 14, 2016 2:46 pm
Would this http://www.amazon.co.uk/Goliton%C2%AE-B ... wifi+combo help?
Providing your keyboard/mouse is bluetooth of course.
mikerr
Thu Jan 14, 2016 2:59 pm
jamesh wrote:Would this http://www.amazon.co.uk/Goliton%C2%AE-B ... wifi+combo help?
That would be great if it weren't so relatively expensive. wifi dongles can be £1, bt dongle £1 .. but no combined ones for less than £15 :(
Thu Jan 14, 2016 4:07 pm
I know, it's a bit odd.
bobby21
Tue Feb 07, 2017 3:33 pm
You may want to check HubPiWi Blue that includes a Wifi as well as Bluetooth. The good thing about it is that it does not require any cable or connector. It was one of the best Pi Zero HAT for Pi Zero at kickstarter.
https://www.kickstarter.com/projects/17 ... th-3-usb-p
Martin Frezman
Tue Feb 07, 2017 3:44 pm
bobby21 wrote:You may want to check HubPiWi Blue that includes a Wifi as well as Bluetooth. The good thing about it is that it does not require any cable or connector. It was one of the best Pi Zero HAT for Pi Zero at kickstarter.
It looks very interesting. What is the status of it? Is it "a thing" or is it still basically vaporware?
If this post appears in the wrong forums category, my apologies.
Churu_
Tue Feb 07, 2017 5:56 pm
I just looked into my drawers and found a Trust 2005 USB hub that worked!
Tue Feb 07, 2017 8:08 pm
Martin Frezman wrote:It looks very interesting. What is the status of it? Is it "a thing" or is it still basically vaporware?
Previous kickstarters from the same stable have been successful. I have no reason to doubt this one will be too.
startrek.steve
Wed Feb 08, 2017 9:31 am
I doubt a Zero can provide enough juice to run a keyboard, mouse and wifi without a powered hub, I tried mine with the above plus a bluetooth dongle on an unpowered hub, and it couldnt cope. OK with mouse and keyboard though.
Pi 2 running LibreElec Krypton, Pi 2 running Wheezy Desktop, Pi 1 headless Wheezy, downloading Radio, Pi 1 running Picore headless Media Server, Pi Zero to be an Old Time Radio Project. Pi 3 testing. Pi Zero W downloading Radio shows headless.
