I have recently installed the CUPS printing server on my Raspberry Pi. I had installed it fine and everything would work and print OK - the only problem was that every time I went to go to administrate the printer I added, it would come up with a 'Forbidden' message. I just ignored that as I didn't think I would need to administrate it as I had set up the settings when I installed the printer.
Now today, I was trying to print something and the server got 'stuck' meaning it would not print anything and was showing as 'paused' on my PC (running Windows 10). I had tried a lot of configuration options, and searched on Google - unfortunately nothing worked for me. Eventually I decided to just reset my Pi and I re-installed Raspbian on to it.
I've reinstalled CUPS again but I am still getting the same forbidden message (I only get this when I go to https://<ip-address>:631/printers/<printer>, which is the same issue as before):
I want to be able to fix this error but I am not sure how - so I came to this forum. Any help is appreciated.
Here is my cupsd.conf:
# Sample configuration file for the CUPS scheduler. See "man cupsd.conf" for a
# complete description of this file.
# Log general information in error_log - change "warn" to "debug"
# for troubleshooting...
LogLevel warn
# Deactivate CUPS' internal logrotating, as we provide a better one, especially
# LogLevel debug2 gets usable now
MaxLogSize 0
# Only listen for connections from the local machine.
# Listen localhost:631
Port 631
Listen /var/run/cups/cups.sock
# Show shared printers on the local network.
Browsing On
BrowseLocalProtocols dnssd
# Default authentication type, when authentication is required...
DefaultAuthType Basic
# Web interface setting...
WebInterface Yes
# Restrict access to the server...
<Location />
Order allow,deny
Allow @local
</Location>
# Restrict access to the admin pages...
<Location /admin>
Order allow,deny
Allow @local
</Location>
# Restrict access to configuration files...
<Location /admin/conf>
AuthType Default
Require user @SYSTEM
Order allow,deny
Allow @local
</Location>
# Set the default printer/job policies...
<Policy default>
# Job/subscription privacy...
JobPrivateAccess default
JobPrivateValues default
SubscriptionPrivateAccess default
SubscriptionPrivateValues default
# Job-related operations must be done by the owner or an administrator...
<Limit Create-Job Print-Job Print-URI Validate-Job>
Order deny,allow
</Limit>
<Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job Cancel-My-Jobs Close-Job CUPS-Move-Job CUPS-Get-Document>
Require user @OWNER @SYSTEM
Order deny,allow
</Limit>
# All administration operations require an administrator to authenticate...
<Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default CUPS-Get-Devices>
AuthType Default
Order deny,allow
</Limit>
# All printer operations require a printer operator to authenticate...
<Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After Cancel-Jobs CUPS-Accept-Jobs CUPS-Reject-Jobs>
AuthType Default
Order deny,allow
</Limit>
# Only the owner or an administrator can cancel or authenticate a job...
<Limit Cancel-Job CUPS-Authenticate-Job>
Order deny,allow
</Limit>
<Limit All>
Order deny,allow
</Limit>
</Policy>
# Set the authenticated printer/job policies...
<Policy authenticated>
AuthType Default
Order deny,allow
</Limit>
AuthType Default
Order deny,allow
</Limit>
<Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default>
AuthType Default
Order deny,allow
</Limit>
AuthType Default
Order deny,allow
</Limit>
AuthType Default
Order deny,allow
</Limit>
<Limit All>
Order deny,allow
</Limit>
</Policy>
E [12/Jan/2016:18:58:43 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:58:47 +0000] [Client 21] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:58:49 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:58:52 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:58:54 +0000] [Client 21] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:58:56 +0000] [Client 22] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:58:56 +0000] SSL shutdown failed: Error in the push function.
E [12/Jan/2016:18:59:03 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:05 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:07 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:09 +0000] [Client 20] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:12 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:14 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:16 +0000] [Client 20] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:18 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:18:59:23 +0000] [Client 18] pam_authenticate() returned 7 (Authentication failure)
E [12/Jan/2016:19:01:07 +0000] SSL shutdown failed: Error in the push function.
W [12/Jan/2016:19:02:21 +0000] CreateProfile failed: org.freedesktop.ColorManager.AlreadyExists:profile id 'Dan's_Printer-Gray..' already exists
W [12/Jan/2016:19:02:21 +0000] CreateProfile failed: org.freedesktop.ColorManager.AlreadyExists:profile id 'Dan's_Printer-RGB..' already exists
E [12/Jan/2016:19:02:23 +0000] [Client 18] Request for non-absolute resource "/printers/Dan's_Printer".
E [12/Jan/2016:19:13:17 +0000] [Client 17] Request for non-absolute resource "/printers/Dan's_Printer".
Many Thanks,
Dan.
