ex_directory wrote:I have a new shiny 64gb SDXC, I found the links to format it via windows to 64gb, but when I put the jessie img on the card it shrinks my partition down to 60mb.
What is the correct way to resize this (ideally via ssh) and can I just have one 64gb partition which is bootable?
Windows only reads the 60mb FAT Partition, it is incapable of doing anything else, so your SD Card is showing correctly.
Boot from the card in your RPi and as stated above you can re-size the second partition.
Windows will not see the second partition because it is a EXT Partition, unless you use 3rd party software...
