ChadP
Contact: Yahoo Messenger
gpio
Thu Aug 02, 2012 12:58 am
Dumb question but how do i use the gpio pins, where do i put the code in, im running wheezy. Can i use arduino code that i have already.
mahjongg
Re: gpio
Thu Aug 02, 2012 1:15 am
No you can't, at least not if its assembly language, as the Arduino uses a different RISC architecture.
You might be able to re-use some C code though.
The GPIO's are controllable through sets of library's, different ones for different languages.
perhaps reading some of the magpie magazines might help.
ChadP
Re: gpio
Thu Aug 02, 2012 2:06 am
Ok thanks, so on wheezy id use python to controll the pins, is that correct
mahjongg
Re: gpio
Thu Aug 02, 2012 2:12 am
You can use any language you like, as long as there are libraries to control the GPIO, or if you know how to do the "bare metal programming".
There is documentation describing how to do that, in the form of the Broadcom BCM2835 "datasheet", that can be found on the net (and probably the Wiki).
DexOS
Re: gpio
Thu Aug 02, 2012 3:56 pm
If you want to go the bare metal route, i am work on a project that uses a basic like language, but for things like GPIO its very similar to how you would code the arduino.
Example to flash LED:
include 'DexBasic\DexBasic.inc'
pinMode  GPIO16, OUTPUT                            ; set as output
LetsLoop:                                          ; a label
digitalWrite  GPIO16, HIGH                         ; set LED on
delayMicroseconds  1000000                         ; waits 1 second
digitalWrite  GPIO16, LOW                          ; set  LED off
goto  LetsLoop
align 4
ProgramSize:
ScreenBuffer:
So arduino code would be easy to convert.
If you need more info just ask.
Batteries not included, Some assembly required.
dimonic
Re: gpio
Tue Aug 14, 2012 11:03 pm
The answer you are looking for is the https://projects.drogon.net/raspberry-pi/wiringpi/ library. It comes with a command line utility (gpio) as well.
exartemarte
Re: gpio
Tue Aug 14, 2012 11:41 pm
ChadP wrote:Dumb question but how do i use the gpio pins, where do i put the code in, im running wheezy. Can i use arduino code that i have already.
The Arduino language is a version of C. There is an article showing you how to write, compile and execute a C program on the Pi in issue 3 of The MagPi, page 22.
You can port Arduino programs to the Pi, although you may need to tinker with them a bit and of course anything that directly accesses the atmega hardware won't work because the Pi hardware isn't the same.
See my answer in a another thread to some one who asked a similar question.
Return to “Raspberry Pi OS”
