somewhereinusa
Limit output to two decimals
Sat Jan 09, 2016 10:51 pm
I have finally gotten this to read two DS18B20 sensors. How do I limit the display to two decimals?
#works on 3
import threading
import time
DEVICESDIR = "/sys/bus/w1/devices/"
#class for holding temperature values
class Temperature():
    def __init__(self, rawData):
        self.rawData = rawData
    @property
    def C(self):
        return float(self.rawData) / 1000
    @property
    def F(self):
        return self.C * 9.0 / 5.0 + 32.0
#class for controlling the temperature sensor
class TempSensorController(threading.Thread):
    def __init__(self, sensorId, timeToSleep):
        threading.Thread.__init__(self)
        #persist the file location
        self.tempSensorFile = DEVICESDIR + sensorId + "/w1_slave"
        #persist properties
        self.sensorId = sensorId
        self.timeToSleep = timeToSleep
         #update the temperature
        self.updateTemp()
        #set to not running
        self.running = False
    def run(self):
        #loop until its set to stopped
        self.running = True
        while(self.running):
            #update temperature
            self.updateTemp()
            #sleep
            time.sleep(self.timeToSleep)
    def stopController(self):
    def readFile(self):
        sensorFile = open(self.tempSensorFile, "r")
        lines = sensorFile.readlines()
        sensorFile.close()
        return lines
    def updateTemp(self):
        data = self.readFile()
        #has a YES been returned?
        if data[0].strip()[-3:] == "YES":
            #can I find a temperature (t=)
            equals_pos = data[1].find("t=")
            if equals_pos != -1:
                tempData = data[1][equals_pos+2:]
                #update temperature
                self.temperature = Temperature(tempData)
                #update success status
                self.updateSuccess = True
            else:
                self.updateSuccess = False
        else:
if __name__ == "__main__":
    #create temp sensor controller, put your controller Id here
    # look in "/sys/bus/w1/devices/" after running
    #  sudo modprobe w1-gpio
    #  sudo modprobe w1-therm
    #Engine
    tempcontrol = TempSensorController("28-011561b31cff", 1)
    #Outside
    tempcontrol2 = TempSensorController("28-021561a10dff", 1)
    try:
        #print("Starting temp sensor controller")
        #start up temp sensor controller
        tempcontrol.start()
        tempcontrol2.start()
        #loop forever, wait for Ctrl C
        while(True):
            #print tempcontrol.temperature.C
            print ("Engine temp")
            print (tempcontrol.temperature.F)
            print ("Outside temp")
            print (tempcontrol2.temperature.F)
            time.sleep(1)
    #Ctrl C
    except KeyboardInterrupt:
        print ("Cancelled")
    #Error
    except:
        print ("Unexpected error:"), sys.exc_info()[0]
        raise
    #if it finishes or Ctrl C, shut it down
    finally:
        print ("Stopping temp sensor controller")
        #stop the controller
        tempcontrol.stopController()
        #wait for the tread to finish if it hasn't already
        tempcontrol.join()
    #print "Done"
kusti8
Re: Limit output to two decimals
Sat Jan 09, 2016 11:16 pm
There are 10 types of people: those who understand binary and those who don't.
somewhereinusa
Sun Jan 10, 2016 4:44 am
I have looked at that post many times over the last week. There are at least four answers, which seem to be dealing with money. I think my biggest problem is I don't know where to put it.
ghp
Sun Jan 10, 2016 7:38 am
could go to
            print ("Engine temp {et:.2f} Outside temp {ot:.2f}". format( et= tempcontrol.temperature.F, ot=tempcontrol2.temperature.F))
(untested).
Regards,
Gerhard
somewhereinusa
Sun Jan 10, 2016 2:33 pm
Thank you,thank you,thank you.
That is exactly what I needed.
Dick
Return to “Python”
