What i'm trying to do is connecting an Arduino to my RPi 2 through USB serial port (without USB Hub).
My RPi 2 is running Raspbian Jessie.
The arduino version that I've used is both Arduino Uno and Arduino Nano. With bot i'm having issue finding the serial port.
NB. I'm not using the Arduino IDE. Do I need it to make it works? maybe any driver missing?
Instead the "dmesg" command output this:
[284803.322999] usb 1-1.2: New USB device found, idVendor=2341, idProduct=0001
[284803.323032] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[284803.323048] usb 1-1.2: Product: Arduino Uno
[284803.323065] usb 1-1.2: Manufacturer: Arduino (www.arduino.cc)
[284803.323081] usb 1-1.2: SerialNumber: 752303137333514092E1
Bus 001 Device 007: ID 2341:0001 Arduino SA Uno (CDC ACM)
/dev/tty /dev/tty19 /dev/tty3 /dev/tty40 /dev/tty51 /dev/tty62
/dev/tty0 /dev/tty2 /dev/tty30 /dev/tty41 /dev/tty52 /dev/tty63
/dev/tty1 /dev/tty20 /dev/tty31 /dev/tty42 /dev/tty53 /dev/tty7
/dev/tty10 /dev/tty21 /dev/tty32 /dev/tty43 /dev/tty54 /dev/tty8
/dev/tty11 /dev/tty22 /dev/tty33 /dev/tty44 /dev/tty55 /dev/tty9
/dev/tty12 /dev/tty23 /dev/tty34 /dev/tty45 /dev/tty56 /dev/ttyAMA0
/dev/tty13 /dev/tty24 /dev/tty35 /dev/tty46 /dev/tty57 /dev/ttyprintk
/dev/tty14 /dev/tty25 /dev/tty36 /dev/tty47 /dev/tty58
/dev/tty15 /dev/tty26 /dev/tty37 /dev/tty48 /dev/tty59
/dev/tty16 /dev/tty27 /dev/tty38 /dev/tty49 /dev/tty6
/dev/tty17 /dev/tty28 /dev/tty39 /dev/tty5 /dev/tty60
/dev/tty18 /dev/tty29 /dev/tty4 /dev/tty50 /dev/tty61
What should I do? I've not installed the Arduino IDE yet, because what i'm trying to develop shouldn't require it.
