sudo apt-get remove webmin
Reading package lists... Done
Building dependency tree
E: The package webmin needs to be reinstalled, but I can't find an archive for it.
pi@raspberrypi:~ $ sudo apt-get install deluged deluge-console deluge-web
J'ai essayer une commande trouvé sur internet mais rien n'y fait :
(http://askubuntu.com/questions/267016/t ... ive-for-it)
pi@raspberrypi:~ $ sudo dpkg --remove --force-remove-reinstreq --dry-run webmin
dpkg: warning: overriding problem because --force enabled:
dpkg: warning: package is in a very bad inconsistent state; you should
reinstall it before attempting a removal
(Reading database ... 123971 files and directories currently installed.)
Would remove or purge webmin (1.780) ...
- http://askubuntu.com/questions/490671/f ... ed-package
- http://askubuntu.com/questions/267016/t ... ive-for-it
Je dois réinstaller le package mais comment faire ? Merci pour votre aide. Bonne soirée
