wwihead
Best Ribbon Cable for Sense Hat?
Fri Jan 08, 2016 11:15 am
Hi everyone
Is there a best 40 pin ribbon cable to get as I want to try separating the Sense Hat to get a more accurate temperature reading. Also, do I need anything more to get the connection working?
Thanks so much
Kratos
Re: Best Ribbon Cable for Sense Hat?
Fri Jan 15, 2016 11:26 pm
As long as it is a ribbon cable, it should work.
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
mahjongg
Sat Jan 16, 2016 12:22 am
Actually no! If its an old PATA cable it can cause big troubles, they look like 40 pole flat cables but actually they carry 80 wires, more info here viewtopic.php?p=665572#p665572
using one may blow up your PI! :oops: :(
geppetto
Sat Jan 16, 2016 10:09 am
I've just ordered one of these for the same purpose
https://shop.pimoroni.com/products/black-hat-hacker
Phil
Kratos
Sat Jan 16, 2016 4:11 pm
I almost did that. Fortunately I realized it was a PATA cable before I plugged it in.
Kratos
alphanumeric
Tue Jan 19, 2016 2:35 pm
You can get tall stacking headers at places like Adafruit. https://www.adafruit.com/products/1979 It's what I'm going to try. Just plug it in between the Pi and sense hat. I have one on the way. I should have it in my hands by weeks end hopefully. I made a weather clock with my sense hat so I want good readings of the ambient temp. Right now I'm not getting that. The heat from the CPU is pushing my temp reading up to 30 C.
The old 40 wire, 40 pin IDE cables should work. You will also need a double row of long header pins. The Pi in male pins but the sense hat is a female header. The new 80 wire, 40 pin IDE cables are the ones to avoid. A couple of wires/pins are grounded/shorted for drive select.
sparkie1
Thu Aug 04, 2016 12:06 pm
Hi
Does anyone have any advice on how to get the Sense HAT working with a GPIO extension cable? I bought an extension from Pimoroni, and a 40 pin male-male IDE header from eBay. The HAT works perfectly on my B+ when plugged straight in. Using the extension cable, only the green and red LEDs light up and the pi refuses to boot. Reversing the orientation of the cable leads to no LEDs and no boot, so I think I'm the right way around.
The only problem I can think of is that the IDE header pins are too short, and are not making a good contact with the HAT's contacts. Is this a possibility? If so, does anyone know where I can get a set of longer pins?
Rob
alphanumeric
Thu Aug 04, 2016 6:11 pm
sparkie1 wrote:Hi
Rob
You have to make sure pin 1 on the GPIO is connected to pin 1 on the sense hat. The red strip isn't the only thing to go by either. I bet yours is reversed. Pin 1 is going to Pin 2 and Pin 2 to Pin 1, etc. I "think it needs to be plugged into the sense hat from the top? Checking the +5V and +3.3V voltages on the sense hat header with an volt meter should tell you.
sparkie1
Sun Aug 07, 2016 8:16 am
Hi, thanks for the advice alphanumeric, you were correct.
For anyone having the same problem (partial lighting up of sensehat with red and green LEDs only, no successful boot) then it is likely that the ribbon cable has reversed the top and bottom layer of pins.
The solution, which was not immediately obvious to me, is that you can take the female header off the bottom of the SenseHat. The frees you up to insert the cable from the top side of the hat.
Ribbon cable inserted from the top by removing the hat header
kairi
Wed Oct 05, 2016 8:58 pm
I had exactly the same problem and got it fixed, thank you a lot for the solution @sparkie1 ;) !
webrtchacks
Sat Jan 26, 2019 11:55 pm
I have a project where I needed to plug the ribbon cable into the back of the sense hat instead of the front. I was struggling on how to reverse the pins and then I realized I could easily do this by joining 2 cables. I used some header pins (https://www.amazon.com/gp/product/B00U8 ... UTF8&psc=1) to connect two ribbon cables.
It is a little long but does the trick.
dpawson
Fri Aug 09, 2019 1:14 pm
https://www.dominicsayers.com/sense-hat/ Seems quite logical, unless you want the sense hat on top of the
rpi - not good for an rpi 4.
Purchased. Mounted RPI 4, fan (usb powered), sense hat.
Ribbon 'stretches' the standoff posts, misaligns hat!
https://drive.google.com/file/d/1A6KNR_ ... sp=sharing
Return to “Astro Pi”
