I have two Raspberry Pi model B v1.1
Both were up and running fine since Sept 2015 when I purchased them.
I have HDMI monitors and USB mouse and keyboard connected to both (individually).
One of the Raspberry Pi's(Alpha) will not boot. The other Raspberry Pi (Beta) boots normally.
Alpha's Red Power LED is on and stays on and the Green ACT LED turns on but does not blink. The Ethernet Nic has no LEDs on
1. Tried swapping Pi's. Beta worked with all of the Alpha monitor/nic/monitor/keyboard. Alpha did not work with Beta's monitor/nic/keyboard/mouse.
2. Tried swapping SanDisk 8GB micro SD card. The SD card from Alpha worked fine in Beta. Beta's card did not work in Alpha
Not sure what else to check.
Any Help would be appreciated. Thanks
