Hi, I hace a new raspberry, y use startx in Raspbian, and then I reboot it. But, it appears a new login screen, I enter pi/raspberry and it take it as good, but it returns me to login screen.
Help, please
AndyD wrote:Can you provide a little more information?
"I use startx" ... was your Raspberry Pi show the Desktop (big Raspberry in the middle of the screen) or just the console (text screen, mostly black, with one or four Raspberries in the top left hand corner)? What exact command did you use to startx?
"It appear a new login screen" ... When you say new, do you mean different to the screens you have seen before? Can you describe this new screen?
Did you by any chance change the password for the pi user?
I try both of them. I reintsall system about 4 or 5 times. I try it both of them.rpdom wrote:Did you type "sudo startx" at any time? That will mess things up. startx must run without sudo.
rpdom wrote:Typing "sudo startx" causes trouble.
Other people have had the same problem. How to fix it is here viewtopic.php?f=63&t=130879
Default behaviour is::M4STER_ANGEL wrote:I'm in the same case... When I install it from NOOBS for first time, it shows me automaticaly the Graphical interface
It's not a bug, it's an implementation choice by the RPF. There's an option in sudo raspi-config to change the default behaviour.QuietZone wrote:How to fix that bug? Thanks.
Balderdash and poppycock. Bugs are caused by idiot programmers, so that the systems programmers have something to do for their day jobs.QuietZone wrote:Most bugs are, in the end analysis, "implementation choices".
One man's meat, ...
