Hi everybody,
would it be possible to use the Wolfson Audio Card and the official Display in combination ?
I've tried, but it seems as if the necessary GPIO pins are not routed through the Audio card ...
Regards,
n
Aside: I'm using the new Wolfson on a Raspberry Pi 2 ..DougieLawson wrote:The bigger problem is that the Wolfson kernel won't have the official display code built in to it. They don't keep up with all of the kernel development. My model B with the old Wolfson card is running with a kernel built in April 2015.
The support for the Wolfson/Cirrus cards isn't just patchy, it's 100% non-existent.
Hmm not really, when i don't connect the SCL and SDA cables, the screen just stays black ...6by9 wrote:?? The display doesn't require any gpios unless using it old rev B, and you say you're on a Pi2. I2c-0 is routed up the flex to the display.
All 40 pins on the main gpio header are available for your use to the audio card.
Getting a working kernel is another matter.
Sorry, i was wrong, it works perfectly fine if i use the usb powering method, without the jumper wires ... don't know what i did wrong before ... strange ...EllipsenPark wrote:Hmm not really, when i don't connect the SCL and SDA cables, the screen just stays black ...6by9 wrote:?? The display doesn't require any gpios unless using it old rev B, and you say you're on a Pi2. I2c-0 is routed up the flex to the display.
I've followed the instructions as presented here:
http://thepihut.com/blogs/raspberry-pi- ... mbly-guide
That little rainbow square means your power supply isn't good enough. It's not "a little activity square". Since power demands are variable depending on how much work the CPU is doing I can see how you'd be confused by it.EllipsenPark wrote:The only thing that's different now is that the little square (denoting activity ?) on the upper right corner of the screen is missing ...
Oh, ok ... but i'm using the same adapter as before ...DougieLawson wrote:That little rainbow square means your power supply isn't good enough. It's not "a little activity square". Since power demands are variable depending on how much work the CPU is doing I can see how you'd be confused by it.EllipsenPark wrote:The only thing that's different now is that the little square (denoting activity ?) on the upper right corner of the screen is missing ...
