Tue Jan 05, 2016 6:07 pm
wayne007 wrote:I've installed NOOBS and when to Raspian. I'm trying to connect a 7" display via a TFP401. As I understand I need to edit Config.txt to set the HDMI on yet I can't see a Config.txt file on the SD card when I read it on my laptop. Am I missing something?
New and would appreciate any help!
Wayne
The NOOBS installer has its own, built-in editor for
config.txt etc.**:
https://github.com/raspberrypi/noobs#ea ... ile-editor
(Accessed from "recovery mode" - hold/toggle a Shift key during boot)
Trev.
** Windows doesn't understand the part of the uSDHC (ie. the partition format of) card where
config.txt lives (and, if you choose to install more than one O.S. there's a
config.txt for each O.S. installed)
