buzzersdad
how to connect a usb memory stick
Tue Jan 05, 2016 2:01 am
I'm trying to get Raspbian to recognize a USB memory stick. Simonsmall wrote recently:
First issue this command -
pi@raspberrypi ~ $ ls -laF /dev/disk/by-uuid/
total 0
drwxr-xr-x 2 root root 120 Jan 1 1970 ./
drwxr-xr-x 6 root root 120 Jan 1 1970 ../
lrwxrwxrwx 1 root root 15 Jan 1 1970 1A8A-8E1C -> ../../mmcblk0p1
lrwxrwxrwx 1 root root 15 Jun 21 17:53 1B97-0057 -> ../../mmcblk0p5
lrwxrwxrwx 1 root root 15 Jun 21 17:53 53990179-b4d2-8e98-1c7d-a23b681c0419 -> ../../mmcblk0p6
lrwxrwxrwx 1 root root 15 Jan 1 1970 c37891bd-e98a-97e2-81cd-b3c78d7c93b5 -> ../../mmcblk0p3
pi@raspberrypi ~ $
This shows the "devices" that the hardware knows about, in this case the parts of the SD Card that NOOBS created.
Now, plug in the thumb drive into a USB socket. Type the same thing again.
total 0
lrwxrwxrwx 1 root root 10 Jun 17 11:36 38C1-D07C -> ../../sda1
pi@raspberrypi ~ $
There is a 'new' line that shows what the thumb drive has been called, in this case "sda1")
Trouble is, in my case there is no new line with sda1 or anything else. The output is identical both times. What is wrong? I have files on the memory stick I want to use on the Pi (tar files). How do I get Raspbian to "see" the memory stick so I can hook it into the file structure? (Yes, I'm a complete newbie...)
Re: how to connect a usb memory stick
Tue Jan 05, 2016 8:10 am
buzzersdad wrote:I'm trying to get Raspbian to recognize a USB memory stick.
This looks like a problem with your memory stick. You should really start a new thread for that [edit]That's been fixed. Ta.[/edit]
However, try this to see if your stick is even recognised:
1. Plug in your stick.
2. Wait about 5 seconds
3. Type: "dmesg | tail -20l"
4. Post the output.
You should see something like:
pi@raspi3 ~ $ dmesg | tail -20l
[   15.967360] random: nonblocking pool is initialized
[   16.840559] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   23.985753] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:102400k SSFS
[   29.416539] uart-pl011 3f201000.uart: no DMA platform data
[61157.959164] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[61158.142206] usb 1-1.4: New USB device found, idVendor=0781, idProduct=5572
[61158.207926] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[61158.276656] usb 1-1.4: Product: Cruzer Switch
[61158.314690] usb 1-1.4: Manufacturer: SanDisk
[61158.352383] usb 1-1.4: SerialNumber: 4C530012000622118254
[61158.409615] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[61158.473610] scsi host0: usb-storage 1-1.4:1.0
[61159.510380] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Switch    1.27 PQ: 0 ANSI: 6
[61159.587754] sd 0:0:0:0: [sda] 31266816 512-byte logical blocks: (16.0 GB/14.9 GiB)
[61159.663672] sd 0:0:0:0: [sda] Write Protect is off
[61159.706528] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[61159.707035] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[61159.711134] sd 0:0:0:0: Attached scsi generic sg0 type 0
[61159.860408]  sda: sda1
[61159.890814] sd 0:0:0:0: [sda] Attached SCSI removable disk
Ignore the first few lines. It's the bit from "new high-speed USB device" onwards that are important.
Navyscourge
Re: Missing most of tools in NOOBS installed on Pi2?
Tue Jan 05, 2016 8:13 am
It is a pity that you did not read the last post on that thread - it is from back in June, and there was a problem where two people were asking different questions and everyone got confused.
It would help us a lot if you could copy your post into a new thread, then post a link to that thread in this one. That will make the answers you get a lot clearer.
texy
Tue Jan 05, 2016 8:27 am
Navyscourge wrote:It is a pity that you did not read the last post on that thread - it is from back in June, and there was a problem where two people were asking different questions and everyone got confused.
Done.
Texy
