Jarlexx
Folder stuck in void?
Mon Jan 04, 2016 11:07 pm
I was going to move a ~20gb Plex folder from my SD-card to an external hard drive by doing
sudo mv ~/Plex/ /media/USBHDD1
However, the folder disappeared from my home folder, and did never appear on the hard drive :? I've been waiting for some hours now because I thought the transfer would take some time, but the folder seem to be gone? I've tried to do a search through the desktop File Manager, but without any result. When I look at the free space on my SD-card, it seems like the folder still is on the card.
Any ideas how I could find my folder?
karrika
Re: Folder stuck in void?
Mon Jan 04, 2016 11:15 pm
What about
find / -name Plex -print
or
find /media -name Plex -print
You could also look what folders take up the space by the command du
du --max-depth=2 /media
Jarlexx
Mon Jan 04, 2016 11:48 pm
karrika wrote:What about
or
Thank you for your reply. I checked which folder that takes up space on my SD-card and got this output
0	proc
0	sys
4.0K	dev
4.0K	mnt
4.0K	root
4.0K	srv
16K	lost+found
16K	~
29K	media
68K	tmp
868K	run
5.6M	etc
7.6M	sbin
7.9M	bin
18M	home
20M	boot
20M	boot.bak
283M	lib
635M	opt
800M	var
2.5G	usr
So there are no folders which takes up all the space on the card (The SD-card is 32gb with only 2 gb of free space left).
When I search for Plex with 'find', there is a Plex folder in '/~/', but the content is just empty folders.
EDIT: I solved this problem by following this thread viewtopic.php?t=71520&p=521414
It seems like there was a problem with the mounting of the external hard drive, so all the files were placed in /mnt/media instead. These files were not visible without using sudo mount --bind / /mnt and sudo ncdu -x /mnt. I am now moving the files back to where they belong :D Thanks!
