I was wondering, can you use the Sd micro card inside the SD holder. I tried to copy the operating image over by win32 image software. I keep getting nothing. It is 0 data on the sd micro card.
I am using the operating system they have on the raspberry pi down load page which is Raspbian Wheezy. The win32 image seems to work at first, it reads and then writes.
Then it says it has done it and you click close. But when you check the sd micro card it is empty.
I unconpressed the folder zip file and saved it and then used win32 image to read and right the image and save it to the drive where the sd card is on.
Do you only use a SD card or can you use the micro sd card in side the sd holder.
I am using a Kingston sd micro sd card. It also said that you dont use a genric sd card.
Regards
