Sfraser01
Travelling with pi
Sun Jan 03, 2016 12:46 pm
My raspberry Pi works fine in Canada but when I try to use it in Florida it does not work. Do I need to reprogram my SD card?
Sandy
mahjongg
Re: Travelling with pi
Sun Jan 03, 2016 1:07 pm
No!
but you do not supply enough information, what do you mean by "not working".
Sfraser01
Sun Jan 03, 2016 1:12 pm
When I plug in the Pi it boots fine and I get everything I get in Canada but when I try to view a tv show it does not load the show.
kusti8
Sun Jan 03, 2016 1:23 pm
We still need way information than that. What show? What OS are you using? The OS boots up fine? What do you see instead of the normal behavior?
beta-tester
Sun Jan 03, 2016 1:28 pm
Sfraser01 wrote:When I plug in the Pi it boots fine and I get everything I get in Canada but when I try to view a tv show it does not load the show.
you mean 220V/110V power plug problem?
you mean analog TV problems PAL/NTSC/SECAM
or HDMI 60Hz /50Hz/24Hz
or legal problems (video streams / content blocking by ip-region)
or what else?
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
drgeoff
Sun Jan 03, 2016 4:17 pm
or what else?
The first three of those are exactly the same in Canada and Florida.
QuietZone
Sun Jan 03, 2016 4:27 pm
It'd be interesting to know more about OP's setup - what viewer/browser/OS combo is being used on what TV show - but on the surface of it, and this was my first reaction on seeing the post, it seems almost certain that it is a region problem.
I've never heard of this before in the context of Canada vs. USA, but it is well known on these boards that the BBC does not allow people outside the UK to watch their shows online. I assume this is something similar.
"If you haven't got anything nice to say about anybody come sit next to me." — Alice Roosevelt Longworth
Sun Jan 03, 2016 6:48 pm
I'd start by adding
hdmi_safe=1
to the bottom of /boot/config.txt.
If using NOOBS hold [SHIFT] during boot then press [1],[2],[3] or [4] to switch video modes and see if pictures get displayed. Then use the NOOBS config editor to add
hdmi_safe
mikronauts
Sun Jan 03, 2016 7:28 pm
google "geo blocking tv"
its nothing to do with the Pi
drgeoff
Sun Jan 03, 2016 7:52 pm
Dougie has a reputation for not reading all the posts in a topic before weighing in.
Sun Jan 03, 2016 9:12 pm
drgeoff wrote:Dougie has a reputation for not reading all the posts in a topic before weighing in.
At least I suggested something to try rather than your usual complete NON-ANSWER.
Sfraser01
Mon Jan 04, 2016 12:19 am
I am sorry I didn't give you enough info.
The Pi is using Openelec .
When it boots up I get tv addons screen in Kodi.
I go to videos.
I get the Genesis up.
I get a list with Movies, TVShows, Channels, myGenesis, etc.
I go to TVShows.
I get. genders, Year, Networks, etc.
I go to Most Popular.
I get the working wheel in the bottom right for a couple of seconds then nothing.
That happens no matter which option I choose.
Do I need to reprogram the SD card to make it so it can receive US shows?
Sandy
beta-tester
Fri Jan 08, 2016 4:45 pm
Sfraser01 wrote:...
assuming, that what you try to watch is an internet iptv video stream and not an DVB-T/C/S stream via usb dongle, you don't need to change anything on your SD card / configuration.
if you are not able to open a stream, then it is blocked or the format is an other, that the addon does not can handle.
if you, what iptv progrm-/playlist you are using, i know, that some of the iptv playlist contains non-legal rips of usa pay tv broadcasts published...
possibly these videostreams are blocked in the usa, but are available outside of usa.
are all videostreams affected?
can you tell some examples precisely (what is tv show working in canada but not in usa)?
use a legal iptv playlist without any non-legal pay tv broadcasts in it!
DarrenHill
Fri Jan 08, 2016 5:02 pm
Genesis is a very dodgy add-on made for watching pirated streams from illegal sources, so it's more than likely that they are blocked by the US network service provider.
It's on the banned add-ons list for the main Kodi forum due to its sources.
